Tell Me What To Do With My Hardwoods!! - Flooring - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 07:03 PM   #1
Question
Tell me what to do with my hardwoods!!
Newbie here, so bear with me...
So, I'm buying an older home that needs a bit of work. The hardwoods throughout the main level leave much to be desired. They aren't scratched or anything, just worn. Looking at the photo, do you think they need to be resurfaced or refinished? And should I use water-based or oil-based poly?
I really appreciate your expertise and guidance!
~D~
Dcf0708 is offline   Reply With Quote
Old 04-14-2013, 07:08 PM   #2
Rewards Points: 13,748
Make some local calls to some floor refinishers.
By the time you buy the materials, rent the equipment, get though the learning curve on how to use it, they could have been done and gone and been about the same price.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Dcf0708 (04-14-2013), oh'mike (04-15-2013)
Old 04-14-2013, 07:15 PM   #3
Thanks for your input Joe. I plan to have a flooring expert come out to the home too, but I like to obtain objective advice from those who aren't trying to get my business too, lol.
Old 04-14-2013, 08:40 PM   #4
Rewards Points: 3,630
Oil based is the better of the two,but will take longer to cure if that makes a difference.
Canarywood1 is offline   Reply With Quote
The Following 2 Users Say Thank You to Canarywood1 For This Useful Post:
Dcf0708 (04-16-2013), oh'mike (04-15-2013)
Old 04-15-2013, 12:37 PM   #5
Rewards Points: 264
Your floors look like they need to be sanded down and refinished. As it appears that the finish has completely worn off in the higher traffic areas. I would suggest Bona Woodline for oil finish, or Bona Traffic HD for water finish. The water is the harder finish of the 2, and it has less odor, dries faster, & cures faster.
Awoodfloorguy is offline   Reply With Quote
The Following User Says Thank You to Awoodfloorguy For This Useful Post:
Old 04-15-2013, 01:21 PM   #6
747
registered
747's Avatar
Rewards Points: 534
You have money in those floors. They just need to be sanded and refinished. I would recommended a pro. Finally oil based seeing how your not living there. (It takes longer to dry and about a week to loose the smell.) But its worth it.
747 is offline   Reply With Quote
The Following User Says Thank You to 747 For This Useful Post:
Installing hardwoods, cant locate studs GlennM515 Flooring 6 06-29-2011 07:40 PM
Old homes - Hardwoods everywhere??? Clemsig07 Flooring 1 06-15-2011 08:41 AM
Thoughts on Kahrs Spirit / Award Hardwoods seventyfour Flooring 0 05-23-2011 03:27 PM
salvaging the floors under glued down hardwoods christymichael General DIY Discussions 5 03-07-2011 07:31 AM
Can I put hardwoods on top of existing travertine? jmwinke Flooring 11 11-22-2009 01:33 AM
