Tearing Up The Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 03-14-2005, 08:26 PM   #1
Tearing up the floor
I had a rather ambitious idea to tear up the tile and plywood in my kitchen in order to expose the pine floor underneath. It's all done except for around the cabinets and I can't reach under the overhang of them to cut the rest. what can I use? I don't want to remove the plywood from underneath them because I need the height. thx.
lemans68 is offline   Reply With Quote
Old 03-14-2005, 08:38 PM   #2
aka:awesomedell
Rewards Points: 150
Send a message via MSN to housedocs
Tough problem there, if we're redoing the kitchen floors we opt to pull the base cabinets generally. Can you release the fasteners anchoring it to the floor/wall and lift it up and set it temporarily on some blocks to get the clearance in order to cut back up under the kickplate. Or might be able to get a wormgear saw up in there, but I doubt it. Hope that helps a bit.
housedocs is offline   Reply With Quote
Old 04-18-2008, 01:11 PM   #3
You can buy a tool called a toe kick saw for under cabinet cutting. It is an offset type radial saw with a small blade. A company called Crain (#795) makes one, it is not usually found in rental shops.
iread is offline   Reply With Quote
Leaking bathroom floor patatura Flooring 6 12-06-2008 07:30 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
old uneven bathroom floor toubob Flooring 4 02-15-2007 02:39 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Help wih floor extremer1519 Flooring 1 12-27-2005 07:33 PM
