Tear Out Hardwood Or Not? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-26-2013, 08:47 AM   #1
WJColion's Avatar
Tear out hardwood or not?
We need to replace the downstairs carpet in this rental property. It currently has hardwood in the entry and kitchen/eating area. We'd love to put vinyl planking in the living room, but are concerned about the transition from the vinyl to the hardwood. It it worth trying to find vinyl that's similar to the hardwood? Or get something completely different looking? Or should we just bite the bullet and pull the hardwood out of the kitchen/dining area too? Photo included for reference
Any suggestions would be greatly appreciated!
WJColion is offline   Reply With Quote
Old 07-26-2013, 11:46 AM   #2
Rewards Points: 13,456
Real wood flooring adds value, laminate lowers it, I'd leave it.
Consider prefinish engineered flooring instead.
May even be able to add a thin layer of plywood and get them even.
WJColion (07-26-2013)
Old 07-26-2013, 12:07 PM   #3
WJColion's Avatar
What is prefinished engineered flooring? We don't want to put in laminate because it doesn't withstand spills well. We're considering Allure Ultra.
Old 07-26-2013, 12:58 PM   #4
MarginallyQualified
Rewards Points: 2,464
Get some new carpet.
Old 07-26-2013, 02:44 PM   #5
Rewards Points: 274
If it is rental property then carpet would be fine.
alexjoe is offline   Reply With Quote
Old 07-26-2013, 03:04 PM   #6
To Recap..you are considering puliing out that beautiful hardwood and installing Allure in its place??
I don't mean to be rude but please give your head a shake..
Is your thinking clear now?? I can see pulling it out if your planning on a upgrade but not a downgrade. Tumbled Travertine maybe, but not cheap flooring.
I agree with the others. Just replace the carpet.
creeper is offline   Reply With Quote
Old 07-26-2013, 03:56 PM   #7
WJColion's Avatar
haha, thanks creeper. I showed your comment to my husband and he finally agreed to leave the hardwood in. As for replacing the carpet, yes, we are replacing the carpet. But we're certainly not putting new carpet in. What, just to replace it again next time we're between tenants? Was hoping for suggestions of flooring that would blend nicely with the existing hardwood. Something durable and easy to DIY.
Old 07-26-2013, 09:07 PM   #8
Engineered flooring has nothing to do with laminate, not even close.
Engineered is plywood with a layer of real wood on top. Mist can even be refinished at least once, the thicker it is the more times it can be refinished.
And yes a DIY can install it.
Tags
flooring , rental , vinyl flooring
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 12:45 PM
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 07:37 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 05:50 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
