Teak In A Bathroom? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 12:21 AM   #1
Teak in a bathroom?
Is teak a viable choice for a bathroom? I mean, it was used for battleship decks , it should hold up pretty well I would think. They say hardwood in a bathroom is not good but I thought that teak was the all weather tough stuff. Or am I missing something important?
willy2763 is offline   Reply With Quote
Old 02-14-2013, 12:29 AM   #2
Rewards Points: 12,832
The teak would be fine, it's the water leaking in under it at the seams that's going to cause the problums.
Old 02-14-2013, 12:47 AM   #3
I see... didn't think of that. I guess there's no way to make that work. So I guess tile is the best option then.
Old 02-14-2013, 01:20 AM   #4
Depends if the the floor joist and subflooring will work with tile.
Did you know you can buy tile that looks like wood?
http://www.bing.com/images/search?q=...tile&FORM=IGRE
Old 02-14-2013, 01:31 AM   #5
Crazy! Thanks for the link. Pretty cool looking options...
Old 02-14-2013, 07:38 AM   #6
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
And if the subflooring won't handle tile, you can buy sheet vinyl that looks like wood.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
oh'mike (02-14-2013)
Old 02-14-2013, 10:45 AM   #7
GBrackins's Avatar
Rewards Points: 2,108
if teak is what you seek ......
you could install a trench style floor drain (with teak floor installed above) and use this product by Schluter to direct any water that gets under the finish floor to the floor drain. You'd have to install a water proof membrane over your subfloor, something like Kerdi. attach teak boards to cross members underneath so that finish floor would not have to be nailed/screwed to the subfloor.
Of course this requires more detail to your work and expense. If it was me, I'd go with the wood finish tiles.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 02-14-2013, 01:45 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 228
Gary,
At first I thought maybe you were kidding, but looks like you're not. I highly disagree with your suggestion.
Jaz
Old 02-14-2013, 02:08 PM   #9
GBrackins's Avatar
Jaz,
I kinda was kidding, because all of the precise complicated work needed to make it happen as well as expense, as compared to a tile floor ...... it can be done however
myself, I'd never attempt something like that
Gary
Old 02-14-2013, 02:56 PM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 820
I love Teak....but the stuff is expensive.............
I have looked at those trench style drains....love the look....but to me to big concern would be moisture under the wood. Even with proper drainage, how would you keep the teak from staying wet underneath all the time?
Old 02-14-2013, 03:38 PM   #11
Davejss's Avatar
Rewards Points: 740
I once did a bathroom floor with ipe. We blind-nailed through the tongues and used a generous amount of silicone around the perimeter between the wall and the expansion gap, and trimmed out with baseboard milled from ipe. The floor was finished with 5 coats of spar varnish. The clients recoated with more varnish a couple of times since the install.
The floor has been down for 12 years and still looks great. The spar varnish really seals well and makes the grain and colors in the ipe come to life.
I would not hesitate to use teak in the same way. As long as your subfloor is cdx plywood or better, Advantech, etc I don't think you'd have a problem.
Davejss is offline   Reply With Quote
Old 02-14-2013, 05:23 PM   #12
Tileguy
JazMan's Avatar
Rewards Points: 228
WOW, you guys are serious. A shower with no pan membrane, just wood or OSB. One little hairline crack will ruin the subfloor, although it could take many years for anyone to notice.
Can anyone direct us the the "spec" that says that's allowed anywhere?
Jaz
Old 02-14-2013, 05:25 PM   #13
JOATMON
ddawg16's Avatar
Rewards Points: 820
Jaz
Jaz....I don't think the OP means for the shower....just the bathroom floor....outside the shower...
Old 02-14-2013, 05:30 PM   #14
Tileguy
JazMan's Avatar
Rewards Points: 228
Maybe to OP does, but someone suggested using a trench drain which indicates the need for a drain. That wouldn't work with wood anywhere.
Jaz
Old 02-14-2013, 11:15 PM   #15
Yes I was just talking about outside the shower. I have no motivation to deal with any drainage issues or anything crazy. I will be replacing the subfloor also so I will hopefully make it so it supports tile. I have never done a floor before and was just wondering why it wasn't advisable. It makes sense now.
Best option for Bathroom Ceiling Paint? tealab Painting 7 04-05-2013 05:49 PM
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 11:14 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 10:47 PM
Basement Bathroom Circuit PJ33P Electrical 1 02-12-2011 08:13 PM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 12:43 PM
