Tar Paper Or Poly On Basement Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 09-29-2012, 05:27 PM   #1
Tar paper or poly on basement floor
I'm currently renovating my basement and am getting ready to frame the walls. Code here says that a moisture barrier (tar paper) is required against the wall prior to the framing.
I'd like to put something down on the floor to stop any moisture from getting through to the laminate I will be putting down. I'm thinking of putting either tar paper or poly down on the floor. I'd like to do this before framing the walls so I can have it extend up the wall slightly. Which would be better?
alexlacelle is offline   Reply With Quote
Old 09-29-2012, 05:43 PM   #2
I did a little more research and found the Delta FL product that's recommended for this. Is it really worth the price?
Old 09-29-2012, 07:54 PM   #3
Rewards Points: 13,458
I'm more concered with you laying laminite flooring below grade, it tend to fall apart.
Engineered flooring would be the way I would suggest, far more stable and below grade rated.
ToolSeeker (10-01-2012)
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Concrete Basement Floor Insulating options McSweny1103 Insulation 7 03-08-2011 05:24 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Basement floor reno D.RED Flooring 1 06-21-2006 02:20 PM
