Tar Paper Between Subfloor And Particle Board? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-15-2013, 01:03 AM   #1
Tar paper between subfloor and particle board?
When taking up the carpet in our bedroom to replace it, I noticed the carpet was laid over 1/2" particle board. So I decided to replace the particle board with 1/2" plywood, but when taking up the particle board I noticed tar paper under it (sub floor - tar paper - particle board). I'm assuming it's either used as a air barrier or to keep the two materials from rubbing together. Should I replace and go back with tar paper or use a different product? Thanks
will02 is offline   Reply With Quote
Old 12-15-2013, 07:37 AM   #2
Rewards Points: 12,856
Tar paper or rosin paper will work.
Old 12-15-2013, 09:39 PM   #3
Registered User
Rewards Points: 4,924
Rosin paper is similar to the Sunday funnies, but cost more (both have about the same perm rating).
Tar paper is sometimes used over a crawlspace, is this the case?
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
will02 (12-16-2013)
Old 12-16-2013, 02:33 PM   #4
Gary
Its a pier and beam house with a crawl space the tar paper is sandwiched in between the plywood and 1/2" particle board. Thanks
Old 12-16-2013, 05:09 PM   #5
Registered User
Be certain you have the crawlspace earth covered with a vapor barrier poly.
IMHO, the tar paper was there to (supposedly) protect the particle board from rising moisture from below as most crawls are vented with the humidity under there-- closely matching outside RH. However; asphalt coated felt paper (5-30 perms) --- or 15# sheathing paper (3-20 perms) would not be my first choice (especially protecting wood strip flooring- not your application- for others) as it is variable permeability (the wetter= more vapor passing through) where AquaBar B is 0.87 perms and your plywood (3/8") is 0.75 perms. So, the plywood alone will slow the vapor coming from the crawl, but not Rosin paper (+50 perms), which could easily become "mold food". You don't need either for a "slip sheet" as the top layer of plywood should be firmly attached to the subfloor boards (and securely fastened to prevent "creep") as an "underlayment" anyway; http://www.google.com/url?sa=t&rct=j...KEftFQ&cad=rja
Use it if it makes you feel better, but most have an odor that lasts a long time. Or if local code requires it, ask AHJ.
Gary
ben's plumbing (12-16-2013)
Old 12-21-2013, 09:48 PM   #6
tar paper. old timers use it and swear by it to this day.
neight is offline   Reply With Quote
Old 12-22-2013, 09:49 PM   #7
Thanks for all the help
