Tar-like Adhesive Between Linoleum And Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 03-07-2008, 05:55 PM   #1
Tar-like adhesive between linoleum and concrete
What's the best thing to use to get that up?
proofer is offline   Reply With Quote
Old 03-07-2008, 05:59 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Razorblade scraper.
Old 03-07-2008, 06:06 PM   #3
I was afraid of that. Since this is taking up the adhesive underneath the tile of a bathroom floor (quite a big space), I was hoping that they made something that you could just pour on and then wipe right off.
But, as always, I appreciate your expertise, Bud.
Old 03-07-2008, 06:30 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Unfortunately the use of any reducers and chemicals in this case would only domino into more serious bonding issues down the road. The (cutback) adhesive must be removed mechanically.
We use wallpaper razorblade scrapers. They come with three inch and four inch blades on a long (18"+-) handle. It's not real difficult.
Easy for me to say.
Old 03-07-2008, 06:33 PM   #5
I'm laughing at myself right now. I was imaging just how long it would take me to use a little (normal-sized) razor blade.
I'm so glad that you described the type that would be simpler for me to use. I'm hoping that a hardware store sells these kinds of scrapers that you mention.
Thanks again.
Old 03-07-2008, 06:59 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I was imaging just how long it would take me to.....
That's why I went into detail. You aren't the first one to think that when a razorblade scraper is mentioned.
It goes pretty quick actually. Get on your knees so you can throw your body weight into it using both hands on the handle. Scrape in long arcs and back away as you go. Turn your scraper over every four or five strokes to keep the blade sharp a little longer.
Old 03-25-2008, 07:16 PM   #7
I'm trying to take this adhesive up right now. I got the razorblade scraper as suggested here. But it leaves a black powder residue still sticking to the concrete. Hopefully if I explain what this stuff looks like in a little more detail, you might see another way to try to take this stuff up in an easier fashion. This house was built in 1965, and I'm sure this adhesive is original to the house. When the linoleum is pried up, the linoleum looks like tar with ridges. We've tried a sander, but that doesn't really do the trick (it gets only a little of it up). Then we tried WD-40, but that just smeared it without removing a thing. The razorblade scraper works just enough to get a little of it up. Any other ideas for me to try?
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Concrete floor over tile Cellomangler Flooring 13 08-25-2012 07:45 PM
correcting slightly uneven small concrete surface amakarevic Building & Construction 5 01-16-2008 08:38 PM
Tile over old linoleum? SeattleDuck Flooring 1 09-22-2006 03:58 PM
