#1 |
tar/felt paper wet between floor & subfloor
I recently discovered water leak in wall between kitchen & bath. Had fans blowing for over a week now, top is dry. Had to cut out the damaged top layer [waferboard] & discovered the tar paper held the moisture real nice. Fans now blowing on subfloor [also waferboard] where the fridge was.
My 1st question is, am I going to have to cut out the top layer of bath floor also? or will it "eventually" dry as a friend suggested? It looks ok, but know it is wet in between also. Second question: the floor under the tub is particale board. It feels dry, but is as soft as a marshmallow. Same friend says not to worry floor joists will hold it up. True, I know, but would like to replace if possible without too much hassel, want to sell this place soon. Is there any way to replace or harden the particle board under a 1 piece fiberglass shower/tub insert? Thanks for any expert advise |
#2 |
There is 0 ways to fix partical board. Once it gets wet one time it's trash.
Remove all of it and replace with Advantec subflooring. No felt needed between it and the underlayment. |
| Display Modes | |
| Subfloor and P-trap for basement bathroom | svaic00 | Plumbing | 9 | 10-11-2012 01:51 PM |
| How should I reinforce this subfloor? | NewHomeDIYGuy | Tiling, ceramics, marble | 35 | 12-05-2011 11:01 AM |
| Old house with paper and fabric over subfloor | twityk | Flooring | 9 | 08-11-2011 03:25 PM |
| Need guidance on subfloor problems in new home. | wb1026 | Flooring | 9 | 10-06-2009 07:29 AM |
| Subfloor / underlayment question... | scheenstra | Flooring | 7 | 02-21-2008 08:39 AM |
