Talk Me Into/out Of These Tile Saws? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-18-2013, 06:22 PM   #1
Dave88LX's Avatar
Rewards Points: 564
Talk me into/out of these tile saws?
I did some reading/researching/reviewing on a tile saw. I didn't
even want to spend this much on a saw, but decided like
any other tool I buy, I shouldn't cheap out. I decided between
reading and justifying a budget, that $300 should get me a
"decent" higher end homeowner saw. I can't justify the $700-
$800 saws for the few small tile jobs I have (this first one is only
30 sqft).
I picked this up today: Kobalt 7" saw sliding tray w/ stand.
$300 - 10% discount + 6% tax = $286
http://www.lowes.com/pd_325792-11241...roduct_price|0
I then found this saw on Craigslist, new in box, still stapled for $350.
http://www.homedepot.com/p/RIDGID-7-...7#.UZf1trV9Dng
Keep the Kobalt? Drop a little more and would I be happier with this RIDGID?
Can 'em both and pick up something else @ ~$300?
Dave88LX is offline   Reply With Quote
Old 05-18-2013, 08:48 PM   #2
DIY staff
Rewards Points: 7,174
Both are small---what size tiles are you planing to cut----???
Old 05-18-2013, 10:50 PM   #3
I've got this model. Ditched the factory blade and bought a Pearl Abrasives blade. So far so good. It rips cuts 18" tile well after squaring the blade, and marking the tile.
http://www.amazon.com/QEP-61024-24-I...words=tile+saw
If I eventually modify it to my liking, I would improve the water line tubes. I would add a tee somewhere and route another line so I get direct water precisely at the cut. As is, it works good.
The gamble is shipping to your door without damage.
Even Further is offline   Reply With Quote
Old 05-19-2013, 07:38 AM   #4
Dave88LX's Avatar
Rewards Points: 564
oh'mike, right now I'm only doing 12" tiles straight across. We are buying a new house with a kitchen floor I'll be doing, about 370 sqft. I'm not sure what size we'll be using. That Ridgid said it'll do 24" tile straight, diagonal across an 18" tile?
Couple others on Craigslist, getting into high-end saw saw prices/category now. Talk about overkill/scope creek for such a small amount of tile! (30 sqft). I will have more tile jobs coming up after this one though, so it makes it a little easier to justify, but it sounds funny now. $400 saw to put down $60 worth of tile.
DeWalt D24000S for $500. Goes for $772 @ Amazon
http://baltimore.craigslist.org/tls/3796428874.html
MK Diamond 770-EXP for $400. Goes for $635 @ Amazon
http://baltimore.craigslist.org/tls/3771103510.html
I guess the MK doesn't offer much more size capability over those first two. The DeWalt with the 10" blade will diagonal cut the 18" tiles; although I've seen where you can use smaller saws to do these cuts doing a pass from each end.
Old 05-19-2013, 07:51 AM   #5
DIY staff
For what you are doing ,either saw will work just fine----cutting capacity on either one is fine for 12" tiles.
I'm spoiled with the big clunky machines I have----
Old 05-19-2013, 10:19 AM   #6
Rewards Points: 12
I have the Kobalt and did 2 tub surrounds and floors with it. It's a great saw. I originally bought the Rigid table but returned it in favor for a sliding table. Change the water frequently. Don't trust the miter gauge. Check it with a square before cutting.
Dan
djlandkpl is offline   Reply With Quote
Old 06-27-2013, 12:42 PM   #7
Dave88LX's Avatar
Rewards Points: 564
Just to follow up on this thread, I ended up buying the Harbor Freight 10" saw at the recommendation of the pros over on the John Bridge tile forum. With a coupon, you can get it at just over $200.
http://www.harborfreight.com/25-hors...saw-69275.html
I put a quality blade on there with great results.
http://www.lowes.com/pd_254983-70-DW4764_0__
Old 06-27-2013, 02:01 PM   #8
Davejss's Avatar
Rewards Points: 740
I usually advise people to buy the best quality tool they can afford. With construction tools best quality usually equals most expensive. But for the person who does maybe two or three tile jobs a year you can certainly get by just fine with cheaper models.
I tend to use a $30.00 scoring cutter for 90% of my straight cuts. Then I use my $90.00 Home Cheapo wet saw for corner cuts and what-not.
The scoring cutter is cheap, fast, accurate and light weight. And I don't have to get up off the floor to use it.
The inexpensive wet saw has held up to a dozen or so kitchen and bath jobs, and one drop down a set of stairs, and it still works fine.
Davejss is offline   Reply With Quote
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 11:43 AM
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 03:29 AM
Ceramic tile over asbestos tile question MLMIB Tiling, ceramics, marble 4 01-10-2011 08:58 PM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 11:05 AM
