Tack Strips To Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 02-12-2011, 09:56 AM   #1
Rewards Points: 1,596
tack strips to concrete
My mother's kitchen (on concrete slab) was tiled.
Now, carpet in adjoining rooms need to be transitioned.
Should a wood tackless strip with concrete nails be used or a metal z-strip?
How to anchor to the concrete? Use liquid nails, polyurethane, contact cement or mechanical fasteners, eg, plastic anchors and screws?
I'm a bit concerned about nailing so close to tile (might miss and chip/crack flooring).
I've searched web and am getting conflicting opinions on best method.
TIA,
Bob
bob22 is offline   Reply With Quote
Old 02-12-2011, 11:01 AM   #2
iam a flooring contractor by trade, and either method will work. technically a z-bar is the standard by the book, but tackstrips will work fine. i have done both for years. the z-bar needs to be fastened to concrete. predrill holes with 1/8" masonry bit and hammer (percussion) drill. drill about 3/4" down into concrete. mark on drill bit with tape for depth guage. nails should be 3/4" fluted masonry. may have to go to local hardware store. can never find at box stores. hammer in nails. if using tackstrips, leave about 1/4- 3/8" gap from edge of tile. Distance will vary depending on carpet thickness. tape tile edges with 3-4 layers of duct tape so you dont nick edges. place tackstrip in place and predrill as above. use same nails and a firm grip on hammmer. go slow. make good contact. nail heads should be flush with tackstrip edge. ALSO, there is a tackstrip adhesive you can buy from a flooring supply distributor. comes in a tube. squeeze adhesive onto floor like liquid nails. activate by misting water onto adhesive. place tackstrip firmly into adhesive. let dry 2 hours. stretch and tuck carpet.
acglobal is offline   Reply With Quote
Old 02-12-2011, 02:58 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 130
We have all used tack strip or z-bar, but technically according to CRI standards, you are supposed to use trac-metal. The only problem is trac-metal looks awful. So I agree, I would use z-bar or tack strip, with the understanding that the carpet will wear out sooner where it sits right on the strip and gets walked on.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 06:11 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 12:03 PM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 10:51 PM
Laid Down Concrete Incorrectly overzealous Building & Construction 6 06-03-2008 06:44 PM
