T-Moulding Around Fireplace And Tile Entry - Flooring - DIY Chatroom Home Improvement Forum
Old 05-11-2010, 01:45 PM   #1
T-Moulding around fireplace and tile entry
Hello, I have a couple of questions that I'm hoping you all can help me figure out.
I just put down a laminate hardwood floor, and I have run into a couple of "problems" that I'm hoping to take care of, but I need some help.
I've drawn up a picture of what my issue is with going around the fireplace.
I don't have enough room, or height to put in the metal strip there, though we're planning on using it by the tile entry.
Otherwise, both will be similar in that I want to use glue on both types of surfaces...Hopefully my attached picture helps you, because I feel like I'm only confusing myself. Thanks for your help!
highway is offline   Reply With Quote
OK to tile over vent/gaps on brick fireplace? roxksears Remodeling 4 01-22-2010 12:48 AM
prepping a fireplace surround for tile rocketdoctor Building & Construction 3 11-30-2009 10:53 PM
Ceramic tile around a fireplace cme Tiling, ceramics, marble 4 11-19-2009 08:26 AM
Transition laminate to higher fireplace tile Slippin Flooring 1 03-17-2009 08:22 PM
Replacing Fireplace Tile doldroyd Building & Construction 4 11-10-2008 03:04 PM
