T-molding - Surfaces Aren't Quite Level - Flooring - DIY Chatroom Home Improvement Forum
Old 10-08-2009, 12:23 AM   #1
Rewards Points: 51
T-molding - surfaces aren't quite level
OK- new problem. I need to transition from my new wood floor to the tile floor in the bathroom. Only 28". The tile floor is barely higher than the wood (I'd say ~1/8"), so I knew the t-molding would be slightly angled, but so little that I didn't think it would be a problem. However, now that I've cut the t-molding, and tested it out, I see that the tile floor has a slight slope. So, the t-molding would be fine on one side, but would have a gap on the other (again, about 1/8").
So, here's my dilemma. Is there something I could use to "level" the slope (similar to a shim)? Or would it be better to use threshold instead of t-molding. The only problems are that the edge of the tile will look rough, and I'm not sure I have quite enough threshold (although I probably would have just barely enough). I'd really rather use the t-molding, since the edge of the tile is really not pretty, but I'll defer to the experts if you tell me it wouldn't work well.
preciouschristy is offline   Reply With Quote
Old 10-10-2009, 12:58 AM   #2
Rewards Points: 51
Wow- I can't believe I stumped you guys
Well, here's what I've decided to do, I think I'll build up the side of the tile that's lower with some caulk or something to make the tile floor level, then lay the t-molding as normal. If anyone disagrees with me, let me know
Old 10-10-2009, 11:19 AM   #3
Tileguy
JazMan's Avatar
Rewards Points: 388
Plane the bottom part of the "T" so you can install it at a slight angle to match both sides.
Jaz
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 05:20 PM
removing/replacing base molding on brittle plaster wall alt Remodeling 3 09-08-2009 09:28 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
Painting baseboard molding same color as chair rail and crown molding Barb Wieczynski Painting 4 04-11-2009 08:32 AM
Help with adding a strip of molding over baseboard. Bobrobert Remodeling 15 01-15-2008 10:12 PM
