T Molding - Flooring - DIY Chatroom Home Improvement Forum
Old 10-19-2007, 04:29 PM   #1
T molding
The tile and wood surfaces are about 3/16" different in height. The T molding will have a slight ramp look transitioning from tile to wood.
If I used Reducer it seems that would present an even larger "bump"
Is going with T the way to go?
NWOKCOWBOY is offline   Reply With Quote
Old 11-12-2007, 06:03 AM   #2
FloorPro
T-Mold Transition
I had the same problem. I looked for a perfect solution for months and I'm in the business. Finally, I had a cabinet shop alter the T-Mold. What I did was trim the base of the molding at an angle. It does have a ramping effect, but no gap under the lip. It worked fine for me.
jerryb48 is offline   Reply With Quote
Old 11-17-2007, 07:15 PM   #3
Floorwizard's Avatar
that's right, sometimes it takes custom work to complete the job.
Floorwizard is offline   Reply With Quote
Painting floor molding with existing carpeting jscott1206 Painting 6 11-08-2008 03:43 PM
Make youre own dentil molding? vendejp Carpentry 4 10-03-2007 11:55 PM
Crown Molding: Lay flat or stand upside-down dtmbizzle Carpentry 15 09-26-2007 11:33 PM
Baseboard molding tiled in... Donald Lynskey General DIY Discussions 1 07-07-2007 06:47 PM
Crown molding finish problem lewlewjones Carpentry 2 05-05-2007 07:13 PM
