T&G Removal - Flooring - DIY Chatroom Home Improvement Forum
Old 03-19-2010, 08:48 PM   #1
Rewards Points: 150
T&G removal
Hello There!
We are installing 3/4 t&g flooring in our living room and hallway. The problem I may have is the hallway currently has a 3/8" or so t&g that is not solid but more like a ply. If I remember correctly when it was put down 15 years ago it seems like I remember the installers using some construction adhesive in the process. If so what is the best way to remove the current t&g flooring with out tearing up the subfloor to much?
I was thinking of something like the Fein Multi Master or the Rockwell Sonic Crafter. Anybody had experience with either of those?
Thanks for any tips or help!
Gary
Gary_602z is offline   Reply With Quote
Old 03-22-2010, 10:46 PM   #2
Rewards Points: 150
Back again!
I ended up buying the Rockwell after reading up on the two products. My lovely bride bought me a pneumatic flooring nailer to do the t&g with, does anybody know what length staples I should use?
I have to get started on this project as I have been putting it off for to long!
Still looking for any and all tips!
Gary
Old 03-22-2010, 11:21 PM   #3
jlhaslip's Avatar
Rewards Points: 2,098
if I recall, I used 2 inch cleats for 3/4 inch t&g
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 03-23-2010, 04:41 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Gary if the 3/8 you refer to is a finished flooring then yes it is plywood. The only way to find out what you are up against is to begin. Start taking out flooring and see what happens.
Is this new flooring prefinished? Why would you need the Sonic Crafter or any tool like it?
You bought a flooring nailer and now you want to use staples??? Don't flooring nailers use flooring nails?
I hope you aren't thinking you can install that 3/4" slat wood with a light weight stapler or Floor Runner. What species of wood is it?
XXX
Old 03-23-2010, 06:58 PM   #5
Rewards Points: 150
Flooring project
Thanks guys!
Bud, the old t&g is definitely a ply, I think parts of it may have been glued down therefor I thought the SonicCrafter may come in handy if I had to seperate it from the subfloor.
The new floor going down is unfinished 3/4 red oak (we did some about 4 years ago). The stapler we got is definitely a flooring stapler Bostich MIIIS(sorry I called it a nailer),you still have to hit it with a mallet but it is air assisted so you don't have hit it so many times like the manual ones.
One can never have to many tools!
Gary
Removal of underlayment under toe space eyeglass Flooring 10 08-26-2009 04:59 PM
asbestos removal timtim General DIY Discussions 3 04-22-2009 06:10 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Lead paint removal Luken8r Painting 3 05-15-2008 07:05 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 12:04 PM
