SwiftLock Vinyl Planks - Flooring - DIY Chatroom Home Improvement Forum
Old 05-01-2012, 06:10 PM   #1
I have a number of questions.
1. Do you need to leave an expansion gap of 5/16 inch around poles?
2. Do you need to leave a gap at doorways between rooms?
3. The directions tell you to stagger the second row by at least 6 inches. Do you continue to stagger the remaining rows (3, 4, 5, etc)?
4. I am installing the floor in the basement on a concrete slab. I was told not to install any underlayment. Is this correct?
5. The concrete floor has expansion joints. I filled them with a concrete caulking. How smooth must the joints be?
Thanks!
Jay Leininger is offline   Reply With Quote
Old 05-01-2012, 06:19 PM   #2
Rewards Points: 13,270
Not a great product to install below grade unless you go to a whole lot of steps before laying it.
If you choose not to follow the directions to the letter your on your own when it fails.
Not sure how told you anything but of there's humps there going to show.
Jay Leininger (05-02-2012)
Old 05-02-2012, 08:42 PM   #3
Why do you say the vinyl planks are not a good product for below grade?
Old 05-02-2012, 08:47 PM   #4
Read the box or go on line and see if it's below grade rated.
Some use partical board in the core,
If you go though some of the older post in the flooring area you will see where people with laminite in basements or even on a slab have the finish coming off, bucking up
I tryed in my laundry room and the first time my drain backed up it distroyed the whole floor.
Old 05-02-2012, 09:55 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Joe, the poster is talking vinyl planks not laminate. No particle board. Still prone to fail below grade, tho.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 05-02-2012, 10:14 PM   #6
What would you install Rusty?
Armstrong says it's ok to use in a basement according to there web site.
Old 05-02-2012, 11:23 PM   #7
Rewards Points: 42
Unless they take care of moisture, anything will fail.
Old 05-03-2012, 01:52 PM   #8
Hello again,
I don't have a mositure problem. Seems like any vinyl could have the same issue if installed with excess moisture.
I still haven't received any answers to my original questions which are stated in the first email. By the way, is SwiftLock an Armstrong product?
peel and stick vinyl wood planks - subfloor prep questions bonanz Flooring 11 12-07-2011 08:41 AM
If vinyl planks are a temporary flooring how temporary? mommiemara Flooring 0 09-14-2011 11:14 AM
Help with peel and stick vinyl planks Rich_B. Flooring 1 05-28-2010 01:30 PM
vinyl planks over cork underlayment mashutka Flooring 0 03-25-2010 11:07 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
