Old 08-24-2011, 10:26 PM   #1
Swiftlock VINYL plank flooring
Does anyone have any experience with this product? Pros/cons/etc?
keithl1967 is offline   Reply With Quote
Old 08-27-2011, 12:46 AM   #2
I have heard of it. HD has Allure, which I'm sure is similar. But if I were you I would google the heck out of it, compare all the brands of the vinyl plank then decide which will be best for you.
ttr13r is offline   Reply With Quote
Old 08-27-2011, 01:31 PM   #3
I have...not a ton out there about this particular product....
I was also looking at the Allure Ultra, but some of the thread discusses the difficulty of proper installation, and having to pull it up and re-install.
I took sample planks from HD of the allure ultra, and also of th eLowes Swiftlock...the swiftlock seems to have an easier, and stronger interlock than the Allure Ultra...
The Allure Ultra is lifetime warranty, though, compared to Swiftlock's 25 year...
Old 08-27-2011, 03:41 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Don't buy anything because one has a lifetime and the other has a 25 year warranty. Most people live in the same house less than 10 years. It can ugly out and still be good under warranty.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
ttr13r (08-27-2011)
Old 11-24-2011, 08:02 PM   #5
The planks were difficult to slide & lock together all the way down, thus producing a crack or gap if not done correctly. Hired an installer who had a difficult time figuring it out & had to take it up and re-lay it after I showed him how to do it. There are still 2 spots in the floor with a slight crack between planks. I didn't have the heart to make him redo it again, but the planks don't lie flat if they are not locked tightly and now there are a couple of places that are chipped at the edge of the plank where the gapped seam is....
eglassell is offline   Reply With Quote
Old 11-25-2011, 03:35 PM   #6
I ende dup going with Swiftlock vinly planking form Lowes', instead of the allure ultra....
The swiftlock goes together well, cust easily, and has none of the "gaps" described here fpr the allure ultra!
Old 12-10-2011, 10:36 AM   #7
So how did it go Keith? Did you have to use any glue at all? Any advice before I get started? I have 21 boxes sitting here waiting for me to get going!
pvsmiths is offline   Reply With Quote
Old 12-10-2011, 12:14 PM   #8
Went pretty smoothly...
Cuts pretty easily (mostky score and snap, but a little more in depth around some corners.
Locks in place well--no issue with it coming apart...one bit of advice, make sure the surface is clean...a very ticky particle can be "felt" throught he floor...
no glue needed...
i would definitely recommend the swiftlock product...
Old 12-18-2011, 10:22 AM   #9
I've put off doing this job because we have questions about how to deal with tile when it meets a wall or door opening. Any experience with meeting up to ceramic tile? http://s1181.photobucket.com/albums/...t=DSC_0221.jpg
or other elevated wood?http://s1181.photobucket.com/albums/...t=DSC_0230.jpg or a metal door frame? http://s1181.photobucket.com/albums/...t=DSC_0225.jpg I'll ask the floor guy at Lowe's, but thought I'd try here also. Will copy and paste this in a similar thread, too.
Thanks for your help, it is truly appreciated!
Old 12-18-2011, 11:45 AM   #10
Is this the installation? I think that you need to stagger the joints, or you could have a problem.
packer_rich is offline   Reply With Quote
Old 12-18-2011, 11:54 AM   #11
All the instrutions your going to need are written on the box.
There has to be a space left where ever it meets a wall,
It can not be ran through a doorway, your going to have to use trasition strips at each doorway. Where it meets tile you once agin need a trasition strip.
What the strip does is allow room for the flooring to expand and contract.
Old 12-18-2011, 12:18 PM   #12
Thanks Joe. Nope, no instructions on the boxes. I did contact the company, and they faxed me some instructions, but they didn't cover the specific challenges I am referring to. I will look into these "transition strips". Thanks again!
Old 12-22-2011, 01:15 PM   #13
No, not the installation, I just put those down to see where I need to start. Will definitely stagger.
Old 12-29-2011, 08:01 PM   #14
My floor trim is going to be a nightmare to remove. I've heard there should be a spacer anyway. Is removing the floor moulding really neccessary?
Thanks!
Sena is offline   Reply With Quote
Old 12-29-2011, 08:11 PM   #15
You have to just remove the 1/4 round or shoe moulding, a simple flat bar and a hammer will just pop it out.
Once out you pull the nails out of the back side with a pair of channel locks.
?laminate or allure vinyl plank flooring? suevwbug Flooring 0 05-09-2011 10:26 PM
Which vinyl plank flooring to buy? CowardlyDIYer Flooring 2 04-10-2011 09:45 PM
? vinyl plank flooring markhelton Flooring 1 12-13-2010 11:35 PM
Feedback on Dura Plank vinyl flooring bmeredith40 Flooring 6 03-15-2009 04:38 PM
vinyl plank flooring? annie68164 Flooring 1 08-18-2008 01:10 AM
