Swiftlock Flooring In Mudroom....... - Flooring - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 07:27 PM   #1
Green Hat
Rewards Points: 170
Swiftlock flooring in Mudroom.......
Gents, i am installing swiftlock flooring in my mudroom coming in from the garage to the basement.
So, long story short.......the builders somehow managed to throw off the square of the room. We are almost 4 inches off from on end to the other.
The room is 5 1/2' x 12'. The off measurement comes on the 12' side, so installing the planks in the direction of the length of the room is out. It will be totally noticeable.
I am thinking that if i install it with the planks going the direction of the 5 1/2' side, it will do a good job of hiding the out of square wall.
Think this is possible? Or has anyone seen anything like this before?
Just looking for options.
Thanks!
Mills314 is offline   Reply With Quote
Old 02-26-2012, 09:42 PM   #2
Missouri Bound's Avatar
How about installing it at a 45 degree angle? I can't imagine a room that small with that much of a up.
But since it's a mudroom, how about a vinyl product?
Do you want it your way or the right way?
Old 02-26-2012, 10:20 PM   #3
Green Hat
Rewards Points: 170
I tried. It looked like ass.
Pulled it up and am going with laminate hardwood. I'm thinking that at a 45 degree angle, it may not lock together right.
They screwed it up by screwing up the stairs next to the mud room. I'm guessing the stairs were a few inches off, then they built the wall. Which threw it off.
Old 03-13-2012, 11:41 AM   #4
You can get swiftlock in a vinyl product. It can look like wood, stone, cork, whatever. In planks or tiles. What type did you go with? If you go with the vinyl type don't forget to also let it sit in your house and acclimate to your environment for a few days.
juvi427 is offline   Reply With Quote
Old 03-13-2012, 03:59 PM   #5
How about ceramic tile.
yogi_bear_79 is offline   Reply With Quote
Old 03-13-2012, 08:11 PM   #6
There's a rubber floor with raised dots, about 3/4". Might be great for a mud room. It's sheet goods.
Swiftlock VINYL plank flooring keithl1967 Flooring 21 06-11-2013 06:34 PM
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 02:00 PM
Install swiftlock plus laminate flooring on a concrete basement Rdavoodi Flooring 1 10-13-2011 03:00 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-29-2011 11:06 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
