Swelling Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 04-17-2010, 12:53 PM   #1
swelling tile
Water was trickling from above ground through our foundation which was causing out tile to warp and swell. Our association came and capped off the area that was exposed ground with concrete but I am still left wth a 3x3ft tile area that is warped. the grout hasn't broken but you can hear the fatigue when you put weight on it. My question is do I need to open up the tile now and let the water underneath dry out and retile or will it in time settle back down with my dehumidifyer?
Thanks you!
kaejor is offline   Reply With Quote
Old 04-17-2010, 02:30 PM   #2
Remodeling Contractor
the tile needs to be removed. The substrate under the tile has absorbed water and now needs to be replaced.
Old 04-18-2010, 01:18 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
HOLD ON!!!
What type of tile?
What type of substrate below the tile?
Let's get some more information before we bring in the wrecking crew.
XXX
Tags
swelling tile , tile
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
