Surface Mold On OSB Board Used In Underlay - Flooring - DIY Chatroom Home Improvement Forum
Old 07-18-2014, 11:45 AM   #1
surface mold on OSB board used in Underlay
Just getting ready to put in a sheet of OSB for underlay on a floor. It was stored outside and there appears to be a bit of surface mold on one side. Is it okay to use it still. It will be covered with white glue and then birch plywood flooring put on top.
symbios2 is offline   Reply With Quote
Old 07-18-2014, 12:04 PM   #2
Rewards Points: 144
I would nit use it.It has drawn moisture and will retain it for some time causing problems with your floor.The last thing you want under a new floor is moisture.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
gmaint (07-20-2014)
Old 07-18-2014, 04:06 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Originally Posted by mako1 View Post
i would nit use it.it has drawn moisture and will retain it for some time causing problems with your floor.the last thing you want under a new floor is moisture.
amen!!!
XXX
Old 07-19-2014, 08:59 PM   #4
Thumbs up
Thanks Mako. We definitely will not use it. Taking it to the dump.
Old 07-20-2014, 05:01 PM   #5
Rewards Points: 13,450
That whole idea sounds bad.
White glue?
Plywood used for finished flooring.
rusty baker (07-20-2014)
Old 07-21-2014, 10:52 AM   #6
Hello Joe,
I know it sounds unusual to use the plywood flooring. However this is often used in Europe. Check it out. We are not only
using white glue but screwing it down as well. We did check into this before using the birch plywood flooring. You use birch plywood that has the thickest veneer of birch. Floor we did two years ago is still looking good.
We put many coats of varathane on top to protect the veneer..
Cement board at tub lip Homerepairguy Plumbing 18 02-22-2013 09:13 PM
Mold on roof sheathing!!! DIYMILF Roofing/Siding 10 08-14-2011 09:11 PM
Mold resolution help needed LeviDIY Remodeling 35 05-04-2011 09:49 AM
Mold in my brand new house ! dumbguy5689 General DIY Discussions 3 09-07-2010 01:26 AM
Connecting Ledger Board to Vertical Stud Alzipski Building & Construction 3 11-04-2009 02:53 PM
