Sunroom Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-06-2013, 09:59 AM   #1
sunroom floor
I have a small sunroom with plywood flooring that does not feel strong enough to lay tile on it. I would be happy putting plywood over it and painting it. Do I need to put some kind of material between the layers of wood?
jaimieruth is offline   Reply With Quote
Old 01-06-2013, 10:05 AM   #2
Civil Engineer
Rewards Points: 4,566
This is a pretty common topic on this forum. You need to determine the flex of the floor, which is commonly referred to as the L/D ratio. You can find this from the John Bridge website. To determine the structural flex, you need to know the size of the joists, the spacing, the clear span, and the species. For small tile, minimum floor flex is supposed to be 1/480 if I remember correctly, and for natural stone or large tile (24"x24") you need 1/720.
You also need to determine the flex between the joists, which is determined by the number of layers of subfloor, the type of subfloor, and the thickness of subfloor. One of the tile setters on this forum can describe minimum requirements between the joists, or you can see a full discussion on the Schluter (they make Ditra) website.
Daniel Holzman is online now   Reply With Quote
Old 01-06-2013, 10:41 AM   #3
Rewards Points: 13,270
Painted plywood is not a great look because of the exposted seams and would require some touch up painting in the high wear areas from time to time.
For a far better look you might want to concider a click lock laminite that looks like tile. Simple to install and not that expencive.
Old 01-10-2013, 08:33 AM   #4
A click lock laminite that looks like tile might do the trick. Its simple to install...
CharmainPhilips is offline   Reply With Quote
Floor joist replacement and reconfiguration WillK Carpentry 2 09-01-2011 09:01 AM
Insulating floor of a bove ground sunroom rbyham Insulation 0 08-07-2011 11:49 PM
Sunroom floor concrete Wando Flooring 2 08-06-2011 11:59 AM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
