Sunken Tile :( - Flooring - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 11:54 AM   #1
Exclamation
Sunken Tile :(
Hello,
We had two non baring walls removed in the kitchen to open it up so the contractors had to replace the tile where the walls were. We had exactly enough tile from the previous owner to lay down what had to be taken out.
When it was all done the tiles that were replaced are sunken down about 1/8-1/4 inch from the other tiles beside it.
They came back out and saw the problem but we have no more matching tiles to pop those out and lay new ones. They mentioned sucking them out and relaying them but not 100% sure they can salvage those pieces.
I think we need to re-tile the whole area????? But not happy about that option because it means more $$$$$
Any thoughts
happyperson is offline   Reply With Quote
Old 03-12-2013, 11:58 AM   #2
Rewards Points: 12,878
Sucking them out
Someone's blowing smoke.
Old 03-12-2013, 12:08 PM   #3
They mentioned using a glass suction tool, the problem is it is in the MIDDLE of the floor
Old 03-12-2013, 01:38 PM   #4
There's just no tool on earth that's going to suck tile up off a floor.
If they were attched right there not going out unless you break them.
Old 03-12-2013, 03:23 PM   #5
The old glass suction tool gag!
Post a picture of the tile. You might be able to find some, depending on how common it is.
oldhouseguy is offline   Reply With Quote
Old 03-12-2013, 03:46 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 244
It's very unusual to do a complete remodel including blowing out a wall and keep the old floor. I'm also LOL about the idea of sucking the tiles out. But, if my hunch is right those guys don't know & don't care much about installing flooring and so who knows what they used to bond the tiles. They would have know the substrate was too low when they did it. Maybe they used mastic? Do you know?
Jaz
JazMan is online now   Reply With Quote
Old 03-12-2013, 06:57 PM   #7
I have no idea what they used, we trusted this company. They only options they had was for us to "go hunting for exact tiles" so they can replace but we have not been able to find a "match". I am going to post pictures here after this post/response. I APPRECIATE your attention to my post. Thank you!!!
Old 03-12-2013, 07:02 PM   #8
DIY staff
Rewards Points: 7,174
Have they grouted the sunken tiles? If not----take a small screw driver and poke at the goo that they set the tiles into---if it's still soft--you have a prayer of removing them---
Old 03-12-2013, 07:10 PM   #9
Here are the pictures
I just want to say that I don't think I am being picky, this is in the center of our kitchen/dinning area.
I also want to say that we DID NOT approve of them to "grout an 1 1/2"" from the wall. I figured they would have asked and we would have founded something similar by the wall.
Sunken Tile :(-img_0812.jpg   Sunken Tile :(-img_0813.jpg   Sunken Tile :(-img_0814.jpg   Sunken Tile :(-img_0816.jpg   Sunken Tile :(-img_0817.jpg
Sunken Tile :(-img_0818.jpg
Old 03-12-2013, 07:12 PM   #10
They came out 2 days later at "our" request and it is already set.... They said "someone" must have stepped on it and or it was our dogs. We made sure not to go through the kitchen while the work was being done. I feel like they threw it back as us.
Old 03-12-2013, 07:15 PM   #11
Your not being picky, that's a complete hack job.
Anyone in the field that knows what they were doing would know that was wrong.
If they knew there was not going to be enough tiles to make the full run they should have known that before even trying to lay them.
Old 03-12-2013, 07:19 PM   #12
Nope they are set!.. Which is dis heartening.
Old 03-12-2013, 07:23 PM   #13
Rewards Points: 2,512
can you post a larger view of the affected area?
hammerlane is offline   Reply With Quote
Old 03-12-2013, 07:24 PM   #14
thank you for your time, we are not conrtactors and paid in full to have this done. If we were approached about the problem and or issues we would have found a way to make it work to our standards. THANK YOU
Old 03-12-2013, 07:30 PM   #15
@ Hammerlane, here are the overall pictures
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 09:03 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 07:03 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
