Suggestions Needed - Laminate On Staircase - Flooring - DIY Chatroom Home Improvement Forum
Old 04-26-2008, 03:58 PM   #1
Suggestions Needed - Laminate on Staircase
I have installed laminate flooring in our bedrooms upstairs and planned to continue to the stairs.
I pulled off the carpet on the top step before doing the hallway upstairs and the stair nosing was a separate piece that I removed so I can install laminate on the back of the top step and install a stair nose piece.
However when I pulled off the carpet on the other four steps today the stair nosing is part of the step. I can't attach the new nosing as it would stick out too far.
My wife and father in law suggested sanding the steps (pine) and staining them to match the laminate that I would need to install on the risers.
I would prefer to install laminate on steps and risers but would expect I would need to cut the existing stair to make it flat.
Would this work and if so how much of the original step should I leave?
Bob_Zahn is offline   Reply With Quote
Old 04-28-2008, 09:23 PM   #2
Can anyone help me?
Old 04-29-2008, 04:57 AM   #3
IMO, Your father in law is on to some thing.................
mark942 is offline   Reply With Quote
Old 05-10-2008, 09:57 AM   #4
Floorwizard's Avatar
cut the stairnose off so it is flush with the riser. then you can install the lam stairnose just fine.
Floorwizard is offline   Reply With Quote
Old 05-10-2008, 03:23 PM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
would you think that the laminate would be slippery when your going down the stairs in your socks? Kids! Kids! Kids! just something to think about,
Old 05-11-2008, 10:08 PM   #6
stair laminate...
When I installed stair-nosings on the stairs I put laminate on, they were very flimsy -- so flimsy that I didn't dare use a dolly on the steps. We regularly slipped down the stairs, and the combination of problems made us swear we'd never put nosings on again.
My buddy put laminate down, and instead of wood nosings, he used a rubberized nosing that you glue down similar to what you're use with lino (I think?) Anyway, it was way better than the nosings I tried.
Hope this helps!
cbeingessner is offline   Reply With Quote
Old 05-13-2008, 10:11 PM   #7
ususally a runner is a great idea when installing lam on stairs.
Also having pieces of carpet cut into squares, having no slip grip glued to the back and then binding will work as well.
Laminate Floor Install - Advice? cmvsm Flooring 18 07-02-2013 01:18 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Best quality underpad to use for laminate?? sillysimms Flooring 4 07-27-2011 05:05 PM
Help me Choose a Laminate Brand DYI_DD Flooring 21 11-15-2008 02:25 PM
Size of laminate layout before t-joints are needed wingman Flooring 1 06-22-2006 09:42 PM
