Subflooring Uneven - Flooring - DIY Chatroom Home Improvement Forum
Old 05-25-2008, 10:38 PM   #1
Post
Subflooring uneven
I am going to laydown wood flooring and notice that in one area that the subflooring is curved upward like a hilltop. I don't have anyway to go underneath the joist to look at the problem since it is on the second floor. Is there anyway to level this out before I laydown the wood flooring?
747dmc is offline   Reply With Quote
Old 05-25-2008, 10:56 PM   #2
Registered User
Termite's Avatar
This often occurs at beams that are upset into the floor joists. It is always a challenge to fix, but you're definately right in wanting to take care of it prior to installing wood flooring.
My suggestion would be to use a floor sander or a belt sander with a 40 grit belt. You can use it to reduce the height of the hump by thinning the plywood or OSB at that location. I'd suggest using a long straightedge to aid in the process. Spraying marking paint on the areas that need to be cut down will aid you in determining where you've been an how much you're taking off.
Old 05-26-2008, 10:15 AM   #3
You need to calculate how high the joist or beam is relative to adjacent area, say 4' on either side. Does it occur in middle of room;adjacent to a wall; does it extend thru a doorway into another area. These conditions will dictate your approach to problem. Use an 8' straight edge to calculate relative height equally on both sides then with the center of your straight edge on the crown bottom one side and measure how high the opposite end is above the subfloor. Repeat process in opposite direction.
Level isn't important here; amount of crowning is.
whatstar1117 is offline   Reply With Quote
fixing baseboard on uneven floors? boodog Flooring 5 10-08-2007 03:20 PM
House with hardwood and no subflooring onyx_asylum Flooring 1 02-25-2007 08:52 PM
old uneven bathroom floor toubob Flooring 4 02-15-2007 01:39 PM
Subflooring Question Fremont Dave Building & Construction 7 01-29-2006 12:27 PM
uneven paint. help Sc00ter Painting 11 08-24-2005 10:57 PM
