Subflooring Help - Flooring - DIY Chatroom Home Improvement Forum
Old 03-31-2014, 11:08 PM   #1
Subflooring Help
Hello, I'm remodeling my bathroom and have a quick question about the sub flooring. Right now I'm down to 1x10s that are nailed into the joists below. I'm planning on putting in tile. The question I have is: do I need additional sublfooring (plywood) over the 1x10s before I put down hardiboard (underlayment?) for the tile, or can I just put the hardboard right down on the 1x10s? I've seen a few different things out there about this, but it might just be me misinterpreting. I'd like to not put the plywood down as it will make the finish grade of the tile a half-inch or more above the hardwood floor outside the bathroom...thoughts?
stencil is offline   Reply With Quote
Old 03-31-2014, 11:20 PM   #2
Rewards Points: 13,456
No you can not just lay tile board over it.
Those old boards flex and are never totally flat.
Tile board adds no strength to the subfloor.
What's the size, spacing and spans of the floor joist?
Going to have to add decking screws to those old boards and go over the floor with at least 1/2" A/C subfloor rated plywood.
Thin set under the 1/4 tile board.
A marble threshold in the middle of the door opening and tile up to it.
How should I go about removing this ruined section of subflooring? 7.62 Building & Construction 7 08-21-2013 07:58 PM
Waterproof subflooring Meliorism Flooring 2 03-19-2013 10:23 AM
Fixing squeaky/loud subflooring during carpet installation thunderbry Flooring 6 05-10-2012 04:01 PM
Increase height of subflooring thiggins18 Flooring 44 02-09-2012 07:08 PM
House with hardwood and no subflooring onyx_asylum Flooring 1 02-25-2007 08:52 PM
