Old 02-03-2011, 05:55 PM   #1
subflooring
So I am removing ceramic tile that is laid on 1" OSB over 3/4" plywood with black paper between. As I removed 1 tile to test the OSB turned into dust.
I plan to put back floating laminate wood flooring but I need to decide what to put back over my plywood subfloor. what is the best most economical choice?
judoant is offline   Reply With Quote
Old 02-03-2011, 06:23 PM   #2
Pro Flooring Installer
rusty baker's Avatar
subflooring
Plywood. OSB is a bad choice for a floor.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Suggested Subflooring over pressure treated decking 112690 Building & Construction 2 10-19-2010 08:54 PM
Suggested Subflooring over pressure treated decking 112690 Building & Construction 3 10-19-2010 07:47 AM
recommended subflooring for hardwood on concrete slab blackcat Flooring 5 10-26-2008 06:15 PM
House with hardwood and no subflooring onyx_asylum Flooring 1 02-25-2007 09:52 PM
Subflooring Question Fremont Dave Building & Construction 7 01-29-2006 01:27 PM
