#1 |
Subfloor suitability question
I'm re-starting my prior thread for accuracy following more research and prior advice on here..
The question is if my subfloor can support porcelain tile/backerboard etc. Right now it's vinyl. Here is the data I have. I'm interested in better understanding the acceptable industry standard.. a. Subfloor is 23/32", OSB b. Pre manufactured I-Joists spaced 19.2 oc, manufactured by International Paper. These joists are labled IPI-200. 9 1/2" top to bottom of the joist. I've viewed a document that I think shows them as L/480 live load, with a maximum simple span of 14' 11". d. The furthest unsupported section measures 13' 7" Can anyone confirm or deny if it's suitable for installation of porcelain tile and the accompanying backer-board based on the information I've provided? I've never installed tile and want to verify I'm not messing-up. |
#2 |
Tileguy
Your framing should be fine for porcelain tiles. I will assume it'll meet L480 at 40/10 lb. per sq. ft. live/dead load, which is common min. code most places. Tile generally needs L360 for both joists and subfloor deflection. I like to specify loads of 50/20 though. You should still be OK for the joists.
Many if not most concrete backer unit manufacturers have ratings for 19.2 o.c. joists too. Wouldn't hurt to add more ply though. What backer are you using? Jaz
Tile 4 You LLC Troy, MI KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME! |
#3 |
Tileguy
Is this the same thread you started "kitchen tile job planning" and the one I spent all that time on trying to help you and now you have just dumped that thread and started this one???
Kitchen tile job planning.. ? .. Or...is it this one in which I also have a sizeable investment? Tile subfloor - clearance issue Just askin"?
#4 |
Yes, it's a continuation from "kitchen tile job planning". And again, thank you very much for your time/help. Hopefully, I didn't violate any forum rule by re-posting, making the title accurate and adding information being my intent.
I had plannned to use the 1/4" hardiebacker. |
#5 | |
Tileguy
Subfloor suitability questionQuote:
![]() You might pick one thread of the three and stay with it as long as the topic doesn't change.
| Display Modes | |
| DRIcore question | trailblazer1229 | Flooring | 0 | 02-24-2010 10:25 AM |
| 3 Phase meter socket question | a320200 | Electrical | 4 | 12-11-2009 01:45 AM |
| An unasked question is the only dumb question | jackie treehorn | Kitchen & Bath Remodeling | 1 | 09-20-2009 09:24 PM |
| A question about water preassure. | reasonforseason | Plumbing | 5 | 04-14-2009 05:36 PM |
| Basement Renovation Question | KUIPORNG | Remodeling | 234 | 08-26-2008 09:19 AM |
