Subfloor Replacement - Prepping For Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 06-01-2012, 05:28 PM   #1
Rewards Points: 109
Subfloor replacement - prepping for hardwood
Pulled up the carpeting in the upstairs bedrooms and confirmed what I had learned when redoing the master bath and feared the same was going to be upstairs - the so-called subfloor is 1/2" C-D plywood that's not T&G and has no blocking between seems perpendicular to the joists.
I am looking to put down 3/4" subfloor, probably Advantech. The room I am starting in (which will be my son's nursery ) is 12x12'. I can cut out the old plywood, install blocking between the joists to support the edges, glue and screw the subfloor. A bit of a PIA, but I have done it before and aside from carrying the OSB panels upstairs it shouldn't be that bad.
The problem is that I don't think I can install blocking at the ends which are parallel to the joists. The last joists are 8" from the wall on one side of the room and 6" on the other. The joists are 16" OC.
I know 1/4" plywood is not structurally sound, but do you think I can get away with leaving the strips of old C-D plywood along the two sides and adding 1/4" B-C on top, making sure I
- glue it
- screw it
- stagger the joints
Thoughts?? The hardwood I am planning on putting down is likely 3 1/4" - 4" wide 3/4" thick solid HW and will run perpendicular to the joists.
Thanks!!
BimmerRacer is offline   Reply With Quote
Old 06-01-2012, 05:42 PM   #2
Rewards Points: 13,446
Going over it with 1/4 would be a waste or time and money.
Two options, go over the 1/2 with the advantec or remove the 1/2 and install the Advantec.
There is no need for blocking at the seams if you use Advantec.
Use constrution adhesive and screw it down with ceramic coated decking screws, it will be more then stuff enough.
Old 06-01-2012, 09:41 PM   #3
Rewards Points: 109
I am not planning on blocking the seems with Advantech. My concern is with the unsuported edges which run along the joists.
prepping for painting on NC home carpenal Painting 13 03-29-2011 11:19 PM
prepping painted basement floor for new epoxy katiepalm Painting 2 11-23-2010 11:00 PM
Prepping Wood for Primer: What Grit Sandpaper? Lovegasoline Painting 2 09-14-2009 10:38 AM
While prepping my walls with TSP - paint bubbled! nikolita Painting 5 12-29-2008 12:29 PM
Any DIY's of cleaning and prepping oil furnace for winter? tripower HVAC 1 10-15-2007 06:54 PM
