Subfloor For Radiant Heat With Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 06-19-2010, 11:50 AM   #1
subfloor for radiant heat with tile
Hello, We are down to the subfloor which is 1/2 thick plywood. The radiant heat we are using is hydro and the tubing will be placed into pre channeled plywood that is 1/2 thick. Can we place 1/4 fiber rock + the barrier paper on top of that and then tile? OR do we need to add to the sub-floor for tile support? Thanks
Jan54 is offline   Reply With Quote
Old 06-22-2010, 02:44 PM   #2
Hello,
we are doing the hydronic radiant heat too and we put Cement backerboard (Durock brand, 1/2") underneath the tile. No Barrier paper. So far we have only put tile in our bathroom and part of the hallway and no problems so far.
SusieQ2010 is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Radiant Heat and Tile Texasguy HVAC 5 04-07-2009 10:14 AM
removing tile over radiant floor heat bayerja Flooring 3 07-15-2008 06:52 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
