Subfloor Preperation For Bathroom Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 04-11-2010, 06:45 PM   #1
Question
subfloor preperation for bathroom tile
I'm installing 12x12 tile on my bathroom floor. I removed the old vinyl and the 1/2in. partical board. The pb was glued in some random spots and some of the 3/4in ply came up with it. The floor joist are 10in doug/fir oin 16in centers. The bathroom is 6ft wide and 14ft long, with the joistsrunning lengthwise. MY plan was to use thin set and 1/4in hardi board before installing the tile. The 3/4in ply subflooring seems ok, but I have concerns about the parts that pulled up. I thought about putting 1/2 ply down first before the 1/4in hardi board or just use the 1/2in hardi board before installing the tile floor. Not sure which is the best way to go. Needing advise in Alaska...
jamillertime is offline   Reply With Quote
Old 04-11-2010, 07:14 PM   #2
add at least a layer of 1/2" underlay first then tile backer
The older I get the better I was
Old 04-11-2010, 07:16 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 232
Hi JA,
No way to tell you if the subfloor was damaged too much, you're the judge. Using 1/2" instead of 1/4" Hardie will only get you a little closer to the ceiling, it will not make your floor stronger. Best bet is to add an underlayment grade plywood, 3/8" min, 1/2" preferred, then the backer board and tiles. Or a membrane such as Ditra instead of Hardie.
Jaz
Old 04-11-2010, 07:20 PM   #4
does your floor feel bouncy like the bath is in the middle of the floor joist span?
Old 04-11-2010, 07:41 PM   #5
The floor seems good and rigid. The tub is at the end of the room running width wise. So I am really not worried about that. The sink and toilet are on the left wall, so the main traffic and weight are in the center pathway to the tub, which has 3 joists on 16in centers. Thanks for your reply...
Old 04-11-2010, 07:58 PM   #6
Thanks you guys for the input... My gut feeling is to do just what you said, because I don't want any problems/cracking,etc. Anyway thanks a million!
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
