-   -   Subfloor pops in winter (http://www.diychatroom.com/f5/subfloor-pops-winter-161872/)
bmorgan 11-01-2012 07:24 PM
My home is 6 years old and in the winter my floor in the living area pops. This does not happen in the summer. This makes me believe I have shrinking and swelling of the subfloor. Additionally I can feel slight movement in some areas. I have pergo laminate flooring and I cant tighten the floor from above. What are some ways to tighten the floor from my crawlspace?
DannyT 11-01-2012 08:01 PM
does it just pop when no one is in the room or is it popping when you walk on it? wood expands and contracts with humidity and temperature changes. all houses do it. are you sure it isn't the laminate floor that is popping?
JazMan 11-01-2012 08:04 PM
Hi,
You always have shrinking and swelling.
SqueakEnder should help some, don't expect miracles though. http://www.youtube.com/watch?v=m2l1ztfRwbA Another choice; Squeak-Relief may help too. http://www.youtube.com/watch?v=zHSK1...ture=endscreen
Jaz
JetSwet 11-01-2012 09:13 PM
Do you have baseboard heat?... If do is the floor touching the pipes?
joecaption 11-01-2012 11:00 PM
Installing that Pergo to tight to the outside walls and in doorways can cause this.
bmorgan 11-02-2012 08:08 AM
We just replaced the pergo flooring because it was doing the same thing before. The builder installed cheap laminate and I believed this was causing the popping. When I say popping, I mean loud wake you up popping. This is not a typical squeak in the floor, however does occur only when you walk on it. When we installed the floors we left the necessary expansion gap. Furthermore, the area that pops feels spongy. We checked the subfloor before putting down the new Pergo and at that time I was convinced it was the old laminate causing the problem. Boy was I wrong! So now what?
