Subfloor Over Floating Concrete? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-29-2011, 06:48 PM   #1
Subfloor over floating concrete?
We just moved into a house that was build in the late 70's. We finished the basement with carpet and new baseboards. After a cycle of seasons we are now noticing that the floor has dropped in random places around the room making the baseboard 1-2" above the carpet. Since this is a "floating" concrete floor underneath, should we build a subfloor on top to resolve the issue? Open to any help...
jmborsheim is offline   Reply With Quote
Old 08-29-2011, 07:12 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
Go back and read what you posted. Some of it makes no sense.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-29-2011, 08:24 PM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
what the heck does this mean?
Millertyme is offline   Reply With Quote
Old 08-29-2011, 11:11 PM   #4
Wow, I thought that this was DIY chat-room, not bash-room. I don't know all the technical lingo for flooring, that's why they call me a newbie. All I know is that I have a problem with my floor and need some advice.
I have a concrete basement floor that we have installed carpet over and added new baseboards. After a year has gone by the floor in some places has dropped so that the baseboards are noticeably gapping above the carpet. I was told that the concrete was laid to float due to the bad soil in our neighborhood so that it would not crack the foundation. In order to solve the gapping issue, can I lay a subfloor over it to keep it level and if so how do we anchor it to concrete that moves.
Is that more clear?
Old 08-29-2011, 11:19 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
No one is bashing anyone. Obviously you couldn't read it either because you somehow managed to re-write it so it made more since. Next time proof read your comments before you submit your words and this won't happen.
Yes.
Take a look at the Drycore (sp) product for openers.
Is that more clear?
Is it? What do you think?
XXX
Old 08-30-2011, 01:05 AM   #6
Originally Posted by Bud Cline View Post
Yes.
Thanks, I'll look into it. Do you know if the concrete continues to shift if the DRIcore will shift with it, therefore still causing gaps?
Someone suggested to us to secure the baseboards themselves to the flooring instead of the wall so it all floated together. Really don't know what is best.
Old 08-30-2011, 07:24 AM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
"Drycore" I'm having second thoughts about that name now. Is it dry core? or dry...something else?
I'm sure it will. Don't know how you would stop that from happening.
Don't see how that would be possible.
I'm still trying to understand what a "concrete floating floor" is. Where are you getting that information?
How about a few pictures of this event?
XXX
Old 08-30-2011, 07:34 AM   #8
Rewards Points: 182
Not bashing. Just had no idea what "&quot, flooring &quot" means.
The Following 2 Users Say Thank You to rusty baker For This Useful Post:
Bud Cline (08-30-2011), ttr13r (08-30-2011)
Old 08-30-2011, 07:03 PM   #9
Its called a floating slab floor and they use it a lot in Denver because supposedly we are in the desert.
Ill try to post some pics soon.
Old 08-30-2011, 07:06 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well that part is correct.
XXX
Old 08-31-2011, 01:04 PM   #11
the Musigician
DangerMouse's Avatar
"floating"
This happens frequently enough around here you "regular" guys should know by now it's a software glitch and not the fault of the OPs. It is simply a "quoting" problem with the vBulletin software. (I believe it happens especially when copy/pasting from other sources/forums)
Let it go people.
...and perhaps you were thinking DryLok?
DM
Old 08-31-2011, 10:17 PM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Perhaps I was.
So why don't somebody call a Geek and fix the glitch?
XXX
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 05:42 AM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 12:06 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 12:03 PM
Trying to install floating floorboards... Hyperian Flooring 4 06-22-2008 04:11 AM
