Subfloor-level Or Replace - Flooring - DIY Chatroom Home Improvement Forum
Old 03-05-2014, 05:56 PM   #1
Subfloor-level or replace
I'm getting ready to lay down laminate and when pulling up the carpet I found that one of the center ply boards isn't close to being level with the surrounding boards. Basically three of the corners are off while the center (length wise) is "close." One corner is level. I'm not sure if I should pull the board or try some leveling compound. The previous owner tried leveling it up with old linoleum before laying down the carpet.
The subfloor is 1.25" T&G plywood. The rest of the floor is in good shape for being built in the 70s.
The center
The even corner.
PapHater is offline   Reply With Quote
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 02:41 PM
When to replace a furnace? stanlam HVAC 3 07-20-2010 07:21 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 07:03 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
