Subfloor With High Spot - Flooring - DIY Chatroom Home Improvement Forum
Old 08-12-2008, 08:41 PM   #1
Subfloor with High Spot
Hi,
I'm in the process of installing some 3/4" hardwood and noticed that on the main subfloor(OSB) there is a high spot over a particular joist. I placed a 7 foot straight edge over this spot where both ends are above the floor around a 1/4". I thought about fixing the joist, unfortunately the basement below is finished, alternatively I thought about using several layers of roofing shingles with felt paper. Is better to hire a professional to fix the subfloor. Any other recommendations?
anthony9887 is offline   Reply With Quote
Old 08-12-2008, 09:51 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
Originally Posted by anthony9887 View Post
Hi,
Your saying the floor is only up a 1/4" and your installing 3/4" hardwood. I would take a belt sander to the high spots. even if you cut down half that you should be fine.
Best High Temp Paint for wood stove?? Sellncars Painting 9 01-21-2009 07:21 PM
Question about regular & high speed USB's mact60 PC Repairs & Upgrades 3 08-01-2008 06:55 PM
Old refrigerator = high power consumption? RammsteinNicCage Appliances 6 06-13-2008 11:50 PM
High Eff. Gas Furnace..? Kyle HVAC 17 12-16-2007 12:17 PM
Breaker for Spot light and outlet receptical hgiljr Electrical 4 08-16-2007 02:10 PM
