Old 01-13-2013, 06:27 PM   #1
Subfloor Help
Hi Everyone, I am new to this forum.
I am working on my living room and had to pull up the carpet and remove it due to water damage. What I found under it was 1/2 particle board as an underlayment and under that is 1/2 plywood as the subfloor. This house was built in 1976, I have basement access to the subfloor above.
I removed the 1/2 particle board due to its condition. The 1/2 plywood is a little bouncy in spots. What I want to do is put in a Bamboo Floating floor, so I am thinking about adding another 1/2 Plywood underlayment, if I go this route, what do I use as far as nails and screws, do I use glue? Do I screw it to the joists or not? Do I put a paper layer between the two sheets of plywood?
Any help is appreciated. Thanks
Mark
markk96 is offline   Reply With Quote
Old 01-13-2013, 06:40 PM   #2
Subfloor Help
Want to fix it right and once and for all?
If you want it right get rid of the 1/2 and use 3/4" Advantec T X G. Constrution adhesive on the joist and ring shank nails of ceramic coated deck screws to attach it to the joist.
The old subfloor can be cut out with a Tow Kick saw and an ossilating saw or sawsall.
That 1/2" subfloor in not doing you any favors.
Old 01-13-2013, 08:14 PM   #3
Subfloor Help
Thanks, I will look into that. I know the 1/2 is weak, and I do want to do it right. If I add another layer offset the seams of the plywood, would that not help?
Old 01-13-2013, 09:24 PM   #4
Tileguy
JazMan's Avatar
Subfloor Help
Joe's suggestion is very good, but sometimes it's not practical to remove the subfloor or it may actually cause other problems. Either method is good.
Years ago homes were built with 1/2" cheapo ply subfloor then covered with a good quality 5/8" underlayment to receive the vinyl floor once the construction mess was over. In the era your house was built most builders changed to a single and thicker subfloor system and let the flooring company prep for the vinyl.
A single 3/4" might be stiffer than two 1/2", but you'd be fine with either. If you just add 1/2" B/C exposure 1 ply, yes of course you have to offset the seams both ways. Do not glue unless you can do a 100% lamination, (very doubtful), and space the sheets about 1/8" Normally underlayment is not fastened to the joists, only to the subfloor, but with only 1/2" subfloor the screws may not bite enough. You won't know until you you do it.
Absolutely no paper or plastic between sheets. Is there a basement, or crawl? Follow installation directions for any moistures tests for the bamboo.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 01-13-2013, 10:01 PM   #5
Subfloor Help
Yes there is a basement with full access to the subfloor above. Nail or Screw? I found Triplay B-C Pine Plywood at Lowes I am thinking about using for this.
Old 01-13-2013, 11:04 PM   #6
Tileguy
JazMan's Avatar
Subfloor Help
No idea which specific plywood you're thinking about or which way you're going.
Jaz
Old 01-14-2013, 09:39 AM   #7
Subfloor Help
I am going to put plywood over what is already there. I do not plan on replacing the current subfloor.
Old 01-14-2013, 09:51 AM   #8
Subfloor Help
You will be just fine adding a new layer of 1/2" ply. Just screw down the subfloor that is there, then stagger the seams of the new ply making sure you overlap the seams of the existing ply. Then glue and screw the new layer. It's not necessary to add a layer of paper between the 2 layers of ply. Hope this helps.
Awoodfloorguy is offline   Reply With Quote
