Subfloor ? For Hardwood Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 05-30-2008, 10:13 AM   #1
Subfloor ? for Hardwood floors
I'm putting hardwood floors in my bedroom and after ripping up the carpet and the 3/4" particle board underlayment i'm left with a 1/2" CDX structural subfloor.
At this point, i question what i need to do about this. My thinking is to lay 3/4" B/C plywood glued and nailed perpendicular on top of the 1/2" The 1/2" is slightly uneven across the joists and i fear anything less than 3/4" layed down is not going to help.
Or
Do i need to cut out the 1/2" sub lay 3/4" t&g ply and be done with it. If i do this would this affect the structure stability of the walls since the walls are built on top of the 1/2"?
WHich is the right way to get this done?
WisBliss is offline   Reply With Quote
Old 05-30-2008, 10:55 AM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
This will be fine. If the dips are extensive, you could use a primer and self-leveling compound or even a modified thinset to float the low areas then install the 3/4".
Or
No. T&G would be used directly over the joists. Since you already have the 1/2" CDX, you can use the b/c plywood over it.
Good luck
Angus
My Albums
angus242 is offline   Reply With Quote
New Hardwood Floors = Strange Natural Gas Odor Vlade Divac Flooring 25 12-04-2014 05:05 PM
Refinshing floors before painting walls? ponchoman1 Flooring 6 03-14-2009 04:21 PM
Want to try to refinish hardwood floors and parquet floors proofer Flooring 11 04-20-2008 05:59 PM
Buckling of Laminate floors branjack Flooring 13 12-26-2007 12:38 PM
Washing my wood floors J187 Flooring 1 11-14-2006 10:13 PM
