Subfloor Framing Q's For 1800's Remodel - Flooring - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 01:03 PM   #1
More Will Than Know How
Subfloor Framing Q's for 1800's remodel
Brand new, kinda feeling my way through this remodel. We have a huge 1800's Colonial and have decided to convert the 3rd floor (attic) into a master suite. Due to the location of the main stack, my plumber says I must raise the floor for the bathroom by 4-6 inches for pitch, which leads to the following questions(I know what I believe is right, but always appreciate expert knowledge):
1. Should I remove existing subfloor or cover with new framing?
2. Should new floor joists be laid parallel or perpendicular to existing?
3. does every joint require a support bracket?
4. What type of wood is common for this application?
Chris
Seilo360 is offline   Reply With Quote
Hiring a contractor for remodel, should they demo to the studs? drew2000 Kitchen & Bath Remodeling 16 01-23-2013 02:56 PM
Remodel vs. repair bathroom slab on grade JCTeacher Plumbing 3 04-15-2012 05:54 AM
Insulation maitenance after remodel k2000lbs Insulation 10 02-19-2012 10:04 AM
Double Bathroom Remodel coreyandnicole Kitchen & Bath Remodeling 1 03-19-2010 09:59 PM
remodel box for wall fixture DIYGST Electrical 4 01-02-2010 03:21 PM
