Old 10-17-2012, 06:24 PM   #1
Subfloor fix before installing hardwood
Installing 4-1/4 & 3-1/4 mix solid hickory over 3/4 plywood. In a couple spots, the top of one piece of plywood is ~1/16 higher or lower than the adjacent sheet. Easier to feel than to see. They aren't crowned and they don't touch. Just a slight difference in height that I would think might cause problems with the flooring (squeaks, groans, or even a visible hitch). Otherwise the floor is level enough (within 1/8 wall to wall).
Is that something I can feather in with felt paper?
zakany is offline   Reply With Quote
Old 10-17-2012, 06:53 PM   #2
Super Moderator
That would work---or slip a thin shim int the gap as you staple or nail the floor.
What wood will bridge a lot of gaps without an issue----If you must put a fastener into a gapped spot--always slip in a shim first----
zakany (10-18-2012)
Old 10-17-2012, 07:12 PM   #3
I have the same question, but in my case there is a crack in the subfloor due to a basement/slab interface. The break is across the breakfast room portion of a kitchen. I hate to level it because it drops about 2/3" from where the break is to a doorway in the wall that leads to a hallway.
Besides vinyl is there any other way to cross an imperfection of any real size without repair?
imautoparts is offline   Reply With Quote
Old 10-17-2012, 10:37 PM   #4
imautoparts go back and repost your own question.
There's no way to keep the ansewers straight when replying to two differant people. And post a picture.
Old 10-18-2012, 09:28 AM   #5
Sounds like a plan.
I like the idea of using 30# felt to make up for small height changes. I'm using Aquabar under my flooring and that seemed to be too thin to use for such build-ups (I'd think too many layers would tend to shift, defeating the purpose). Besides, I care what it looks like before I install my flooring - because I know it's there. That's why I used proper wood screws when I was fixing squeaks rather than drywall screws - the nails had missed the joist so I drilled countersunk holes at an angle to screw the subflooring into the joists.
Another thing that I assume is kosher is that I plan to leave a 1/2-in gap off the walls and undercut the drywall to take credit for its thickness and get my 3/4-in expansion gap. Even though I have good conditions (the basement underneath is dry and is conditioned with the rest of the house with constant air movement in and out) I'm a bit paranoid about cupping, especially with hickory. My wife didn't want nice, dimensionally-stable cherry. "Too red" she said, looking at a floor that was 25 years old.
One thing I find curious is that no one ever mentions a shrinkage allowance. If a floor covering can expand a half inch or so, can it not also contract the same amount? No mention how much the baseboard trim should overhang the flooring edge.
Old 10-19-2012, 05:55 AM   #6
Super Moderator
Base and shoe will cover 1 inch or more--depending on the thickness of the trim---undercutting the drywall is a mess and not really needed---
Old 10-19-2012, 04:33 PM   #7
Already done. It was easy. I just used a scrap piece of flooring as a guide, scored and removed the drywall bottom with a utility knife. Throughout most of my house, the builder left the drywall about an inch off the floor, but not this room. What kept it from getting messy was using a shop vac to clear the debris before it got tracked all over the place.
I'm reusing my baseboard trim. It's ranch style, maybe 3/8 wide at the bottom. Once it's sanded and repainted, it looks nice (well, nicer). I figure that I'd add a 1/2-in shoe mold to the bottom.
Besides, I need something to do while waiting for my wood to acclimate.
Old 10-19-2012, 07:04 PM   #8
Super Moderator
Sounds like you are all set----I seldom reuse any trim--unless it's something rare and unusual.
add up the time spent and you will see why
Extra care in removing trim---$
pulling nails--------------------$
cutting off caulk and cleaning-$
reassembling the quzzel------$
Then ripping it out because the old trim looks--well, old, next to the shiny new floor--
Old 10-21-2012, 06:16 PM   #9
Heh.
That's the difference between a DIYer and a professional. As a homeowner I look at the cost of base molding and think, "why spend that when all I have to do is remove this cleanly, tap out the nails, sand, seal, and repaint?" Save myself a couple bucks per perimeter foot! Sometimes a nail comes out straight. Bonus! Free nail.
I constructed a little sample subfloor that I'm using for practice. I'm "installing" several sample pieces I've collected while looking at flooring.
The Following User Says Thank You to zakany For This Useful Post:
oh'mike (10-21-2012)
Old 10-21-2012, 08:18 PM   #10
Originally Posted by zakany View Post
Heh.
First don't pound the nails back thru. Pull them out from the back. and number the pieces when you remove them.
The Following User Says Thank You to ToolSeeker For This Useful Post:
zakany (10-29-2012)
Installing new hardwood ontop of existing hardwood benshouse Flooring 1 11-13-2009 11:25 AM
Installing engineered hardwood flooring over concrete deborahs Flooring 3 07-30-2009 10:35 PM
Method for installing 3/8" engineered hardwood poolecw Flooring 10 10-31-2008 04:10 PM
Installing Hardwood Flooring selical Flooring 4 10-24-2008 11:45 AM
Installing Hardwood Floor Frank Pantusco Flooring 1 10-26-2007 11:17 PM
