-   -   Subfloor fix before installing hardwood (http://www.diychatroom.com/f5/subfloor-fix-before-installing-hardwood-160405/)
zakany 10-17-2012 06:24 PM
Installing 4-1/4 & 3-1/4 mix solid hickory over 3/4 plywood. In a couple spots, the top of one piece of plywood is ~1/16 higher or lower than the adjacent sheet. Easier to feel than to see. They aren't crowned and they don't touch. Just a slight difference in height that I would think might cause problems with the flooring (squeaks, groans, or even a visible hitch). Otherwise the floor is level enough (within 1/8 wall to wall).
Is that something I can feather in with felt paper?
oh'mike 10-17-2012 06:53 PM
That would work---or slip a thin shim int the gap as you staple or nail the floor.
What wood will bridge a lot of gaps without an issue----If you must put a fastener into a gapped spot--always slip in a shim first----
imautoparts 10-17-2012 07:12 PM
I have the same question, but in my case there is a crack in the subfloor due to a basement/slab interface. The break is across the breakfast room portion of a kitchen. I hate to level it because it drops about 2/3" from where the break is to a doorway in the wall that leads to a hallway.
Besides vinyl is there any other way to cross an imperfection of any real size without repair?
joecaption 10-17-2012 10:37 PM
imautoparts go back and repost your own question.
There's no way to keep the ansewers straight when replying to two differant people. And post a picture.
zakany 10-18-2012 09:28 AM
Sounds like a plan.
I like the idea of using 30# felt to make up for small height changes. I'm using Aquabar under my flooring and that seemed to be too thin to use for such build-ups (I'd think too many layers would tend to shift, defeating the purpose). Besides, I care what it looks like before I install my flooring - because I know it's there. That's why I used proper wood screws when I was fixing squeaks rather than drywall screws - the nails had missed the joist so I drilled countersunk holes at an angle to screw the subflooring into the joists.
Another thing that I assume is kosher is that I plan to leave a 1/2-in gap off the walls and undercut the drywall to take credit for its thickness and get my 3/4-in expansion gap. Even though I have good conditions (the basement underneath is dry and is conditioned with the rest of the house with constant air movement in and out) I'm a bit paranoid about cupping, especially with hickory. My wife didn't want nice, dimensionally-stable cherry. "Too red" she said, looking at a floor that was 25 years old.
One thing I find curious is that no one ever mentions a shrinkage allowance. If a floor covering can expand a half inch or so, can it not also contract the same amount? No mention how much the baseboard trim should overhang the flooring edge.
oh'mike 10-19-2012 05:55 AM
Base and shoe will cover 1 inch or more--depending on the thickness of the trim---undercutting the drywall is a mess and not really needed---
zakany 10-19-2012 04:33 PM
Already done. It was easy. I just used a scrap piece of flooring as a guide, scored and removed the drywall bottom with a utility knife. Throughout most of my house, the builder left the drywall about an inch off the floor, but not this room. What kept it from getting messy was using a shop vac to clear the debris before it got tracked all over the place.
I'm reusing my baseboard trim. It's ranch style, maybe 3/8 wide at the bottom. Once it's sanded and repainted, it looks nice (well, nicer). I figure that I'd add a 1/2-in shoe mold to the bottom.
Besides, I need something to do while waiting for my wood to acclimate.
oh'mike 10-19-2012 07:04 PM
Sounds like you are all set----I seldom reuse any trim--unless it's something rare and unusual.
add up the time spent and you will see why
Extra care in removing trim---$
pulling nails--------------------$
cutting off caulk and cleaning-$
reassembling the quzzel------$
Then ripping it out because the old trim looks--well, old, next to the shiny new floor--:laughing:
zakany 10-21-2012 06:16 PM
Heh.
That's the difference between a DIYer and a professional. As a homeowner I look at the cost of base molding and think, "why spend that when all I have to do is remove this cleanly, tap out the nails, sand, seal, and repaint?" Save myself a couple bucks per perimeter foot! Sometimes a nail comes out straight. Bonus! Free nail.
:laughing:
I constructed a little sample subfloor that I'm using for practice. I'm "installing" several sample pieces I've collected while looking at flooring.
ToolSeeker 10-21-2012 08:18 PM
Originally Posted by zakany (Post 1035237)
Heh.
:laughing:
First don't pound the nails back thru. Pull them out from the back. and number the pieces when you remove them.
