Subfloor Dips...leveler? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-15-2008, 07:04 AM   #1
Rewards Points: 135
Subfloor dips...leveler?
Hi all,
I'm putting new flooring in the whole house. There is a 5 foot by 5 foot area where the floor dips by as much as 3/8". This dip is in a doorway area where a transition from hardwood floor to carpet will be. Is there a leveler I can pour into here that will work for both?
wease is offline   Reply With Quote
Old 09-15-2008, 04:10 PM   #2
Drywall contractor
Rewards Points: 1,070
Sounds like you may have structural issues. Are you on a basement or crawl space where you can see what the problem is? You may have some broken floor joists which can be jacked up and repaired to level your floor. My mother-in-law had a similar situation which I fixed (jacked up and doubled the joists) prior to installing laminate. Not fun doing in a 3' crawl space, but was the proper way to do it. Leveling compound is only a "band-aid" repair if you have bad joists. You may continue to have problems after you put in the new flooring.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-16-2008, 07:15 AM   #3
Rewards Points: 135
This is an area where a shower stall used to exist. Joists looked fine and there is really no settling in the basement area underneath. Looks good, just dips in this area. Very solid area. Just need to level it because of the doorway area.
Old 09-16-2008, 09:51 AM   #4
Drywall contractor
In that case, it sounds like leveling compound would be the fix. Since this is not my area of expertise, I will defer to someone else to suggest the correct type. Good luck.
Organic Floor Leveler??? GeneSilman Flooring 2 08-27-2008 05:22 PM
Self Leveling compound on hard wood floors?? Tbizzy2 General DIY Discussions 3 05-22-2008 11:11 AM
floor leveler roost Flooring 14 04-13-2008 01:07 PM
