Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 09-11-2012, 10:33 AM   #1
subfloor
is it ok to use plywood for a section of the subfloor if the rest is cedar plank? part of our kitchen subfloor has water damage and we need to replace a cedar plank that is damaged. the house is from 1965 and they didn't run the tile under the cabinets - the water damage is from the sink. In any case is this ok - or should we replace with a cedar plank.
anything for or against the plywood? anything for or against the cedar plank? TYIA.
ok - just saw there is a flooring forum - not sure how i missed it. can someone move this over? thanks.
laorquidia is offline   Reply With Quote
Old 09-11-2012, 11:40 AM   #2
DIY staff
Rewards Points: 7,174
Plywood should be fine---thickness is the big issue---
I'll move this to flooring for you---Mike----
laorquidia (09-11-2012)
Subfloor and P-trap for basement bathroom svaic00 Plumbing 9 10-11-2012 12:51 PM
How should I reinforce this subfloor? NewHomeDIYGuy Tiling, ceramics, marble 35 12-05-2011 10:01 AM
subfloor izzyk Building & Construction 0 07-15-2011 05:34 PM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
