Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-28-2012, 05:44 PM   #1
Rewards Points: 89
Subfloor
Okay, I recently removed all of my old subfloor using a combination of tools including a toe-kick saw, jigsaw and chisel. It was impossible to get the old sublfloor completely flush with the bottom plate. When I put down the new subfloor there are gaps in between the new and old. Is this okay? and would I just fill the gaps with something? Also, what length of screws are usually used for the subfloor?
REXAMUS is offline   Reply With Quote
Old 01-28-2012, 05:53 PM   #2
Rewards Points: 13,732
Since a Toe Kick saw can cut right up even to the plate there's should be only tiny gaps.
Once you install the tile board, tile, caulking, base boards and 1/4 round the gaps are covered up.
There should also be insulation under that floor.
Old 01-28-2012, 09:55 PM   #3
Rewards Points: 89
The worst gap is a little under 1/2".
Old 01-28-2012, 10:01 PM   #4
Not sure why it could not have been cut tighter and at this point it does not matter. It will be fine, just make sure the tile board gets cut to fit.
I did not see any screws or nails in that subfloor. (you may have been doing a test fit.
It needs fastners every 4" on the edges and from 6 to 8" in the field.
Old 01-28-2012, 10:07 PM   #5
Rewards Points: 89
Just a test fit...and that toe kick saw is a beast and has a mind of it's own. It kicks like nothing I've ever used before so I was just happy to get around the room without dying lol. Are too many screws a bad thing? I put up some blocking and was going to attach to that as well.
Old 01-28-2012, 10:18 PM   #6
I hear about Toe Kick kicking back on here all the time, for some reason I've never had it kick back on me or any of my guys, but it only take one time for a bad day.
It looks like this is not the subfloor (may be just the blocking I see in the picture) Is it really the underlayment?
The reason I'm asking it there attached differantly.
Sub floor gets screwed to the floor joist.
Under layment never gets attached the the floor joist. It's attached between the floor joist. The reason is your trying to draw the two piece together and get rid of the gap between the floor joist.
Old 01-28-2012, 10:27 PM   #7
Rewards Points: 89
Tried to color code it for you.
Old 01-28-2012, 10:33 PM   #8
First layers called subfloor, the following layers are called under laymant.
Old 01-28-2012, 10:37 PM   #9
Rewards Points: 89
Yea, the only underlayment I will have is Ditra for the tile but I haven't purchased that yet.
Old 01-28-2012, 11:04 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 388
Is that "subfloor" t&g, or regular square edge? Looks like regular 3/4" ply to me. Did you install blocking under the short ends of the new ply too?
Jaz
Old 01-28-2012, 11:18 PM   #11
Rewards Points: 89
Jaz
Regular yes and blocking will be installed on the ends as soon as I put it down for good.
Old 01-28-2012, 11:37 PM   #12
In the future always use Advantec for the subflooring and if your adding 1/2 or 3/4 underlayment always use T & G.
This will make the floor rock solid.
How should I reinforce this subfloor? NewHomeDIYGuy Tiling, ceramics, marble 35 12-05-2011 10:01 AM
How to flatten subfloor hump? loftezy Flooring 9 11-15-2011 12:53 PM
subfloor izzyk Building & Construction 0 07-15-2011 05:34 PM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
