Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 09-08-2011, 02:51 PM   #1
subfloor
i just finished laying 1x6s over the floorjoists(replacing what was original to the house), which way should i go next to prep for the tiling? 1/2" plywood and 1/2" concrete board? or 3/4" plywood and 1/4" concrete board?
jwinters03 is offline   Reply With Quote
Old 09-08-2011, 03:50 PM   #2
Msradell's Avatar
Rewards Points: 84
Either way would work but I would personally go with the 1/2" plywood and 1/2" cement board. It will give a slightly more stable surface for the tile.
Msradell is offline   Reply With Quote
Old 09-08-2011, 04:11 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The 1/2" plywood is only marginally acceptable and none of the cement boards no matter their thickness offers any additional structural stability what-so-ever.
My suggestion would be 3/4" plywood and either cement board would have the same effect. The plywood should be exterior grade/underlayment grade, Exposure 1 plywood.
The cement board also requires a bed of fresh thinset mortar at time of installation along with the use of the proper screws.
XXX
Old 09-08-2011, 04:24 PM   #4
Msradell's Avatar
Rewards Points: 84
1x6's with 1/2" plywood is a perfectly acceptable subfloor.
Old 09-08-2011, 04:37 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
Cement board adds no structural strength at all.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-08-2011, 05:21 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay if you say so.
But when those fresh 1x's begin to crown and cup and curl and distort and they stress that 1/2" plywood and wreck the tile installation don't come crying to me about your error.
If they were seasoned 1x's it would be a different story maybe.
Are the new 1x's tongue and groove?
XXX
Old 09-08-2011, 06:05 PM   #7
Msradell's Avatar
Rewards Points: 84
If they aren't the OP certainly needs to find somebody that knows what they're doing to finish the project!
Old 09-11-2011, 08:35 AM   #8
any good or bad about the advantech plywood for floors? or should i stay with traditional underlayment plywood?
Old 09-11-2011, 10:01 AM   #9
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
Just to ensure your success, what are the joist dimensions and span? Too much bounce and your tiles will crack and/or come loose.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-11-2011, 08:43 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 218
Just so there's no misunderstanding, AdvanTech is not plywood, it's a high quality OSB subfloor.
I disagree with that.
As far as whether to go 1/2" ply and 1/2" concrete backer, or 3/4" ply and 1/4" backer. There is no point of using 1/2" concrete backer on floors. As stated concrete backer adds little strength. Add the thickest plywood you can instead.
Jaz
Old 09-12-2011, 04:12 PM   #11
my floor joists are on 16" on center joists.
on top of that i have 1x6s screwed into place.
floor will be about 315sq. ft.
Jaz, would you recommend going with the advantech? The guys at the local(hometown building supply store. 60 years in business here), took time and broke it all down for me and really made it out to be some good stuff.
agree? disagree?
Old 09-12-2011, 05:54 PM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Jaz while you are at it see if you can drag an answer out of jwinters03 about whether or not the 1X6's are tongue and groove.
Old 09-12-2011, 06:07 PM   #13
No they are not. Regular pressure treated 1x6s. the original floor that i fell through had normal 1x6s. thats what i replaced with. the original floor was 54 years old.
why the big deal over that?
Old 09-12-2011, 06:14 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
No they are not. Regular pressure treated 1x6s. the original floor that i fell through had normal 1x6s. thats what i replaced with. Why the big deal over that?
"Why the big deal over that?"
Because:
1. That type of subfloor must be tongue and groove.
2. Treated lumber is NEVER used in a ceramic tile installation. NEVER!
Not a big deal for me it won't be my mess in a few months. Big deal for you when the treated lumber begins to dry out and shrink and cup and curl and lifts and cracks the tile and grout.
Take it Jaz!
Old 09-12-2011, 06:25 PM   #15
Because:
Take it Jaz!
The floor has been down for 2 months. it is dried thanks to this wonderful GA heat.
the plywood i was going to be putting down is T and G. both(advantech and reg) are sold at local place mentioned above.
what about porcelain tile? Laminate? We want to tile, but nothing is set in stone as of yet. i am doing my research. If you want to help me, im listening. My ears are open.
subfloor izzyk Building & Construction 0 07-15-2011 06:34 PM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Replacing Subfloor whatispunk Flooring 1 09-01-2009 10:50 PM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 09:06 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
