Sub Flooring Structure - Flooring - DIY Chatroom Home Improvement Forum
Old 10-11-2008, 06:05 AM   #1
Sub flooring Structure
I am building a new home and want to use tile what thickness sub flooring should I use?
John_smith is offline   Reply With Quote
Old 10-11-2008, 06:13 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
3/4" Tongue & Groove plywood glued and screwed.
Old 10-11-2008, 08:54 AM   #3
Tile Setter
Over 2x10's (at least) that are 16" on center (or closer) and try not to exceed a 13' unsupported span (the smaller the span the better).
Double the plywood if you change your mind to natural stone.
- Bob
Tileworks is offline   Reply With Quote
Old 10-11-2008, 03:02 PM   #4
JJC
Pro
support for tile or stone
Not trying to cause trouble by posting, only pointing out the wrong info that someone might take as gospel and cause problems down the road.
If you use those joist sizes mentioned, it will not support stone. That's even with two layers of plywood. The span has to be back around 10 to 10.5 ft. ( the span is a guess on my part.) The first sentence is true for stone.
If you are using engineered joists for the building of your home, it is the engineers responsibility to design a system that will support the intended use. It is also the owners responsibility to tell the GC or the engineering firm the intended use. This way they can design a system to accommodate both live and dead load to include what you plan on having for furniture and people.
JJC is offline   Reply With Quote
Old 10-11-2008, 08:42 PM   #5
Tile Setter
No offense here, and thank you for the correction. Seems I had tile on the mind when I spit out my fast fingers response :-)
Yes, for 2x10's that are 16" on center, natural stone requires that the unsupported span is 10 feet or less.
Bigger joists or less distance between them changes it too. For example, with 2x12's 12" O.C. you're good to go with a 13' unsupported span.
- Bob
Old 10-13-2008, 03:57 AM   #6
mikewilson
three two four inches is sufficient thickness.
Last edited by AtlanticWBConst.; 10-19-2008 at 10:51 AM. Reason: Site Rules Violation: Advertising Links Removed From Signature
mikewilson is offline   Reply With Quote
Bathroom Flooring? Whole House Flooring? leezarrd Flooring 9 02-08-2012 01:47 PM
How to cut exhisting flooring in the doorway jjpar Flooring 8 10-26-2011 11:01 AM
Gameroom basement flooring? PaulMcC Remodeling 4 03-09-2006 09:08 AM
