Old 09-29-2007, 09:07 PM   #1
sub flooring removal question
i have torn out carpet and am replacing with bamboo flooring. there is a small portion of the subflooring (2 pieces) that i need to remove due to mold. both pieces are touching a wall and i can't figure out how to get the 2-3" piece next to the wall out. I have used a circular saw to remove the rest. do i have to remove the baseboard?
thank!!
matchley is offline   Reply With Quote
Old 09-29-2007, 10:21 PM   #2
jproffer's Avatar
What's left is likely nailed under the wall, making removal impossible. There's no real reason to remove it. Just butt the new subfloor up against it.
jproffer is offline   Reply With Quote
Old 09-30-2007, 07:53 AM   #3
that is the moldy part...
Old 09-30-2007, 01:12 PM   #4
can you post a photo?
redline is offline   Reply With Quote
Old 09-30-2007, 01:36 PM   #5
Long-Time DIYer
Mike Swearingen's Avatar
Remove the baseboard, use a reciprocatng saw to saw the moldy flooring right next to the wall, and then hammer-and-chisel the remaining moldy wood out.
(Don't try to pull out the baseboard nails. You will probably damage the baseboard. Pull them through as you carefully pry away the baseboard or sink the finish nails holding it with a small straight-shank punch the same size as the nails.)
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-30-2007, 08:26 PM   #6
Mike
This is definetly the bes tway.
flooring dude is offline   Reply With Quote
Old 10-01-2007, 11:59 AM   #7
Hi,
I don't mean to thread whore, but I have a very similar problem and thought that I'd ask here rather then make a new thread.
The only difference with my situation is that I don't have mold, my problem is cat urine. I am going to replace a section of subfloor against a wall, but I am afraid that the subfloor may have wicked it to the edge...which is under the wall frame bottom plate.
Should I bother trying to chissel it out, or would I be best to slap some odor sealer on the bit of subfloor under the frame bottom plate? Or could I save a bit and just smother the section with caulking (being that I would only be able to paint the edge of the effected peice)?
renfrey is offline   Reply With Quote
Old 10-02-2007, 09:19 PM   #8
Originally Posted by renfrey View Post
Hi,
It may be better to incapsulate the odor with some sort of stain/odor blocker if it isn't too bad.
Laminate Flooring Question MillerClemsonHD Flooring 4 02-17-2007 04:49 PM
Laminate Flooring Transition Question flysndoc Flooring 1 01-29-2007 11:48 PM
Wet Flooring Replacement Question RetroActv Flooring 1 04-03-2006 05:57 PM
Laminate Flooring Question cacell Flooring 6 03-03-2006 06:44 PM
Question about mills on laminate flooring cpsilo1 Flooring 3 07-25-2005 01:05 PM
