-   -   sub flooring removal question (http://www.diychatroom.com/f5/sub-flooring-removal-question-11958/)
matchley 09-29-2007 09:07 PM
i have torn out carpet and am replacing with bamboo flooring. there is a small portion of the subflooring (2 pieces) that i need to remove due to mold. both pieces are touching a wall and i can't figure out how to get the 2-3" piece next to the wall out. I have used a circular saw to remove the rest. do i have to remove the baseboard?
thank!!
jproffer 09-29-2007 10:21 PM
What's left is likely nailed under the wall, making removal impossible. There's no real reason to remove it. Just butt the new subfloor up against it.
matchley 09-30-2007 07:53 AM
that is the moldy part...
redline 09-30-2007 01:12 PM
can you post a photo?
Mike Swearingen 09-30-2007 01:36 PM
Remove the baseboard, use a reciprocatng saw to saw the moldy flooring right next to the wall, and then hammer-and-chisel the remaining moldy wood out.
(Don't try to pull out the baseboard nails. You will probably damage the baseboard. Pull them through as you carefully pry away the baseboard or sink the finish nails holding it with a small straight-shank punch the same size as the nails.)
Mike
flooring dude 09-30-2007 08:26 PM
Mike
This is definetly the bes tway.
renfrey 10-01-2007 11:59 AM
Similar Problem
Hi,
I don't mean to thread whore, but I have a very similar problem and thought that I'd ask here rather then make a new thread.
The only difference with my situation is that I don't have mold, my problem is cat urine. I am going to replace a section of subfloor against a wall, but I am afraid that the subfloor may have wicked it to the edge...which is under the wall frame bottom plate.
Should I bother trying to chissel it out, or would I be best to slap some odor sealer on the bit of subfloor under the frame bottom plate? Or could I save a bit and just smother the section with caulking (being that I would only be able to paint the edge of the effected peice)?
flooring dude 10-02-2007 09:19 PM
Originally Posted by renfrey (Post 65696)
Hi,
It may be better to incapsulate the odor with some sort of stain/odor blocker if it isn't too bad.
