Sub Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 02-12-2011, 03:19 PM   #1
Sub Flooring
I am installing porcelain tile once I remove the lino from the floor. My question is, do I have to replace the subfloor or can I just lay thinset, backerboard, thinset and lay my tile. Thank you.
RodneyMc
RodneyMC is offline   Reply With Quote
Old 02-12-2011, 03:43 PM   #2
Experienced
Jackofall1's Avatar
Welcome Rodney, to the best DIY'r site on the web.
You could search for that info, the common practice is to add a minimum of 3/8" ply to the existing subfloor, original subfloor screwed to joist, the addition screwed to subfloor (not joist) thinset, CB, thinset, tile.
Resident experts and on right now so I am sure you will hear from Mr Bud Cline. http://www.diychatroom.com/members/bud-cline-2300/ You can look for posts by Bud.
Mark
Old 02-12-2011, 03:50 PM   #3
Sub Floor
Hey, thanks for the reply but I currently have underlayment (plywood) on the sub floor. Can I lay the BB or CB over the existing underlayment (plywood) or take it up since I have to take linolieum anyway?
Old 02-12-2011, 04:47 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Typically when vinyl floor covering is installed it is installed with a new 1/4" plywood underlayment. If this 1/4" plywood underlayment now exists it must be removed. That type of plywood is problematic when it comes to installing ceramic tile over it.
Once it is removed (if it is present) then you can usually proceed with a tile backer product. If cement board is used it must be installed in a fresh bed of thinset mortar then fastened with nails screws or staples.
To clear up some terms:
A subfloor is an integral component of a structure and is glued and mechanically fastened to the floor joists never to be messed with again. (Hopefully!)
Then on top of that is an underlayment material, probably in your case the 1/4" plywood.
So...
now where are we?
XXX
Old 02-12-2011, 06:32 PM   #5
Sub Flooring
Okay! It is 1/4 inch plywood I think. Some kind of wood defintely. My house is new construction 8 yrs old so the subfloor is wood. If I understand you correctly I can apply backer board or cement board with thinset directly to subfloor add thinset again then tile. I am correct?
Old 02-12-2011, 06:39 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
After removing the 1/4" plywood, yes.
XXX
Old 02-12-2011, 07:01 PM   #7
Sub Floor
Greatley appreciated!
Old 02-12-2011, 07:49 PM   #8
Rewards Points: 1,520
Bud, so no concern about floor flex? What if subfloor is not thick enough and/or joists are undersized?
bob22 is offline   Reply With Quote
Old 02-12-2011, 08:31 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The house is only eight years old, standards eight years ago would be substantial enough for things to work out I would think.
Even if the subfloor is at minimum (5/8") all of today's systems allow for that minimum. I doubt the joists are "undersized" but it doesn't hurt to ask I guess.
Rodney what size are the floor joists, what is their spacing, what is their unsupported span?
XXX
Old 02-15-2011, 10:45 PM   #10
Sub Flooring
Not sure if I measured correctly but on center the floor joist are 16 inches apart and they are Silent Floor TJI/Pro 130 joist. FYI the lino/vinyl was on 1/4 plywood stapled directly to sub floor. I would think that tile on 1/4 backer board would provide same support be the same??
Old 02-16-2011, 12:35 AM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Cement board offers no structural benefit what-so-ever but neither does 1/4" plywood. The 1/4" ply is bad news and should never be used under a tile installation, doesn't matter what you try to put over it.
XXX
Old 02-16-2011, 09:55 AM   #12
Hello,
. I might consider using sheet vinyl. However if it comes in rolls it will be more difficult to layout and mark for cutting. I am dealing with a small room approx 60 sq ft with many obstacles to cut around. Any tips you could provide would be appreciated.
______________
beds, tables
Makepeace is offline   Reply With Quote
Old 02-16-2011, 11:34 AM   #13
Sub Flooring
So does this mean I am good with backer board because I already started applying to sub floor with thinset? The sub floor seems very sturdy and we had no problem when the builder layed the vinyl over 1/4 ply on sub f.
Old 02-16-2011, 06:34 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
  • A subfloor is an integral component of your structure.
  • An underlayment goes over a subfloor when and if needed.
  • A substrate is a flat layer that is below another layer.
  • Cement board is an underlayment (or tile-backer) but underlayments can also be made of other materials.
  • ALL cement boards are to be installed in a bed of fresh thinset and then fastened to the subfloor/substrate with nails screws or staples.
I doubt there is an issue with an eight year old house. Haven't we already been down that road?
If you have already begun installing the cement board then what's the difference now?
XXX
Old 02-16-2011, 07:50 PM   #15
Sub Floor
Okay, I think there was a bit of miscommunication. I was refering to your response above and thought you were saying CB /BB was not structurally sound based on my joist measurements. All is good and thank you so much for your help.
Rodney
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 10:00 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 12:32 PM
