Old 10-01-2012, 07:24 PM   #1
BRT
Sub Floor for Vinyl
I'm planning to install vinyl in my laundry room because I have been advised not to use solid wood flooring. I want a level transition from vinyl to 3/4" wood flooring. So what product do I use to raise the subfloor up? I have cut plywood and there's a lot of voids. Thanks.
BRT is offline   Reply With Quote
Old 10-01-2012, 07:42 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Sub Floor for Vinyl
Use plywood and fill seams with a cementious based floor filler.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
BRT (10-02-2012)
Old 10-01-2012, 08:22 PM   #3
Sub Floor for Vinyl
You need subfloor rated sanded plywood, that way the voids are filled in the core.
BRT (10-02-2012)
