-   -   Sub Floor for Vinyl (http://www.diychatroom.com/f5/sub-floor-vinyl-158624/)
BRT 10-01-2012 07:24 PM
Sub Floor for Vinyl
I'm planning to install vinyl in my laundry room because I have been advised not to use solid wood flooring. I want a level transition from vinyl to 3/4" wood flooring. So what product do I use to raise the subfloor up? I have cut plywood and there's a lot of voids. Thanks.
rusty baker 10-01-2012 07:42 PM
Use plywood and fill seams with a cementious based floor filler.
joecaption 10-01-2012 08:22 PM
You need subfloor rated sanded plywood, that way the voids are filled in the core.
