Sub Floor Squeaking In High Traffic Area - Flooring - DIY Chatroom Home Improvement Forum
Old 05-25-2013, 06:57 AM   #1
Rewards Points: 65
Sub floor squeaking in high traffic area
Have squeaking in subfloor in high traffic area which is of course annoying in a less than 3 yr. old new home. Cannot easily shim from underside ~ drywall ceiling making joists not easily accessible. Have low-med pile carpeting on floor. Suggestions greatly appreciated.
rpulley825 is offline   Reply With Quote
Old 05-25-2013, 07:06 AM   #2
Rewards Points: 14,306
I'd roll the carpet back, find the squeck and add some screws.
rpulley825 (05-25-2013)
Old 05-26-2013, 01:49 PM   #3
MJ Force's Avatar
Rewards Points: 150
A long time ago, on a squeaky floor, where the carpeting was glued down, I drove the screws right through the rug! It worked. Couldn't see the holes.
However peel back the rug if you can.
MJ Force is offline   Reply With Quote
Old 05-26-2013, 04:43 PM   #4
Rewards Points: 65
sub floor squeaking
Thanks, M J. I will try to peel back carpet first. it is just outside entrance to bedroom so hopefully will not be too bad. just have to pull back a corner/edge maybe 18 inches
Old 05-27-2013, 05:37 AM   #5
CitadelBlue's Avatar
Rewards Points: 97
I'm doing some prep work on my subfloors before installing hardwood floors. The subfloor is currently nailed down and I'd like to add screws. What's the recommended length, how far apart and and near should I add screws to the current nails?
CitadelBlue is offline   Reply With Quote
Old 05-27-2013, 07:00 AM   #6
DIY staff
Rewards Points: 7,174
1 3/4" or 2" gold screws work well---depending on the condition of the sheeting---every 8 to 10 inches apart.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
CitadelBlue (05-27-2013), rpulley825 (05-27-2013)
Old 05-27-2013, 07:24 AM   #7
Rewards Points: 65
oh'Mike ~~ how about underlayment screws?
Old 05-27-2013, 09:16 AM   #8
DIY staff
That would be ideal-----
Lighting layout for lounge area timbo59 Electrical 3 11-21-2011 05:37 AM
Electrical Problem w/ New AC Blower Motors - High Speed shuts off after 15 Min? Tyndale Electrical 6 07-10-2011 03:58 AM
What to do with area about tub surround? geowoman Remodeling 7 05-05-2007 01:56 PM
prefinished flooring dulling in high traffic area. yummy mummy Flooring 4 12-19-2006 09:40 PM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
