Sub Floor Sound Barrier??? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-15-2010, 10:45 PM   #1
sub floor sound barrier???
We are installing a sub-floor and wanted to know what type of product we should use to help prevent the extreme hollow sound. Any suggestions would be greatly appreciated!
missemma001 is offline   Reply With Quote
Old 02-16-2010, 12:45 AM   #2
Contractor
Brickie's Avatar
Rewards Points: 79
Welcome to the forum!
Northwest Indiana Masonry
http://www.nwindianamasonry.com
Brickie is offline   Reply With Quote
Old 02-16-2010, 09:38 PM   #3
Why not
Can we get some more information about your project? For starters....is this a second floor subfloor?
You will get a lot more response if you move this post out of introductions and maybe into "Construction" or "Remodeling" below in the index
noahweb is offline   Reply With Quote
Old 02-17-2010, 05:47 AM   #4
Carpet.
jerryh3 is offline   Reply With Quote
Basement insulation / vapor barrier questions deepstuff Building & Construction 16 02-09-2012 10:11 AM
vapour barrier on ceiling of bathroom? wilsonfrench Building & Construction 20 01-29-2012 09:08 PM
Rigid insulation/vapour barrier in crawlspace shtoink Building & Construction 2 10-10-2009 12:00 AM
To Vapor Barrier Or Not to Vapor Barrier, That Is The Question. joegambler Building & Construction 5 09-18-2009 10:40 PM
Moisture Barrier for Partially Below Grade Grouted CMU Wall Fire4Effect Building & Construction 4 07-06-2009 12:51 PM
